Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
X25-M Gen 2: Win7 Setup / Tweaks
Just received my Gen 2 160gb Intel SSD. Wondering if there are any setup recommendation or tweaks to perform when setting up my new opertating system.
Thanks!
Community Manager
To prolong drive life, you might want to consider turning off things like System Restore and the Search Index that can cause more drive activity than usual. Windows 7 is supposed to handle most other things on its own, and should automatically disable defragmentation, for example.
I'd generally maintain the drive as an OS/application drive, and if you're ever extensively downloading, storing media, etc., put those things on another drive.
Intel is supposed to have firmware with TRIM support out within the next couple months, and I'd upgrade to it once available.
