cancel
Showing results for
Search instead for
Did you mean:
X25-M SSD manufacture date and usage
DAndr17
New Contributor
Hi All,
I'm looking to buy an 160GB X25-M SSD (SSDSA2MH160G1GN) advertised as brand-new.
- is there any way to find out its date of manufacture using ISN/SA/WWN? (prior to buying it)
- is there any way to make sure it's never been used indeed once I have it?
Many thanks in anticipation,
Dmitriy
1 ACCEPTED SOLUTION
Kevin_M_Intel
Contributor II
Hello DmitriyA,
Let me help you with this.
The numbers printed on the layer will work when replacement is needed but I regret to say that there is no way to know the Date Of Manufacturing using those number; however, I can confirm all SSDs are completely new and we do not refurbish SSDs.
It is also important to for your to check the place of purchase or the vendor. But if you get it from Intel® or any of Intel® retailers or if the box is seal for sure it will be a brand new product.
4 REPLIES 4
Kevin_M_Intel
Contributor II
Hello DmitriyA,
Hi kevin_intel,
Thanks for your response back then - I recall having some issue when trying to get back to you like thread seemed closed and have just come across it while preparing another Q.
What SSD health check application would you recommend (ideally made by Intel) that'd help understand whether an Intel SSD was likely in use or is brand-new?
Also wondering where I can find a comparison between G1 (50nm) and G2 (34nm) Intel SSDs, e.g. SSDSA2MH080G1GC vs SSDSA2MH080G2C1?
Many thanks in advance,
Dmitriy
The Intel tool we have is called Intel® Toolbox and you get details from there. If you would like to do a comparison chart you can use the ARK.Intel.com
Here you have a link with more information about the SSD comparison:
http://forums.anandtech.com/showthread.php?t=2023198 http://forums.anandtech.com/showthread.php?t=2023198
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Kevin M
Hi Kevin - many thanks!
- assuming Intel Toolbox = Intel SSD Toolbox - perhaps I just overlooked all the details it provides, will try again then
- the G1 vs G2 comparison is spot on and here's the one for 80GB ones: http://ark.intel.com/compare/56601,56604 http://ark.intel.com/compare/56601,56604
(I'll be submitting a few more Qs on G1 vs G2 that are specific to my expected usage pattern in a separate thread shortly)
Kind Regards,
D.
