Community
cancel
Showing results for
Search instead for
Did you mean:
LC9
X25-M freezed during the Intel Toolbox optimization and not recognized after a power off.
Hello Guys!
My X25-M 80GB G2 was freezed during the Intel Toolbox V3 optimization and not recognized after a power off. I had waited 20 minutes to power off.
The machine is a netbook Asus 1101HA with ATA compatible mode.
The drive have worked for over 3 years in this machine and I had never used the Intel Toolbox in past.
Anyone have a solutions to restore this drive?
Tags (2)
Jose_H_Intel1
Hello gnogni,
You may want to explain a bit further about how is the drive not recognized, is it in Windows* or in BIOS?
In case the data is not a concern it may possible to run a low level format or secure erase on the drive. Otherwise, you may first check with a professional data recovery service as others have done /message/200509# 200509 here.
LC9
Hi joe!
Not found in any BIOS.
Not found in Windows XP / 7 / 8.
Not found via a sata-usb adapter.
No delay when I connected it to my pc via the hot swappable sata2 or sata3 channels.
I've tested this drive in three or four ways:
a Asus 1101HA with sata in ATA compatible mode;
a pc Pentium-4 with sata2 in ATA compatible mode;
a Sony notebook with sata2 in AHCI mode;
a pc i7-3770k with sata2 and sata3 in AHCI mode (AsRock Z77 Professional).
It wasn't found by all them.
Johnny_Y_Intel
Looks like the driver is dead, please contact Intel support for warranty if still within warranty period...
Jose_H_Intel1
I am sorry, based on your description it appears to be defective. Please also note this drive has 3 years of warranty.
