Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
X25E Toolbox & Trim Support
Are the X25E drives such as:
http://www.newegg.com/Product/Product.aspx?Item=N82E16820167014&cm_re=intel_x25e-_-20-167-014-_-Prod... http://www.newegg.com/Product/Product.aspx?Item=N82E16820167014&cm_re=intel_x25e-_-20-167-014-_-Prod...
able to use the Intel tool box? Are they supported by trim?
The above link shows a 'G1' drive. Is there a later version or a firmware update?
Thankjs
Mitch
Community Manager
The G1 drive does not support trim and never will according to Intel. I'm not sure if the toolbox will work with it either. I don't think it will.
Community Manager
Yes the Intel SSD Toolbox will work with G1 drives. The Optimizer (trim) however only works on G2 drives
