Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
X79 SMART not enable
Hi
Just installed a new system with a gigabyte GA-X79-UD3 mobo and a Intel 520 SSD.
My SSD toolbox won't run the optimizer and also says that SMART is disable.
I can't see anything about SMART in the BIOS.
How do I get this running?
Best regards
Mic
Community Manager
You may have your 520 connected to the Marvell 9172 (Ugh!!) SATA interface, and not the Intel SATA interface. The SATA ports on your board are different colors, and you need to check which color belongs to what SATA interface, and determine where your 520 is connected. Once you figure that out, we can take it from there.
Also, what SATA mode are you set to on each of those different SATA interfaces, and what drivers are you using with them?
Community Manager
Not connected to Marvel.
All sata are to ahci ( correct spellig? ) in the bios.
I've installed all the driver for the disk coming together with the mobo.
Community Manager
I've located the problem.
It's the "Intel Rapid Storage Technology Enterprise" driver which is on the driver cd for the Gigabyte motherboard.
As soon as this is installed the toolbox reports, SMART feature not enable.
The driver is version 3.0.0.1112. Have also tried with version 3.0.0.3020 but same problem.
Strange that Intel makes a driver which screws up its own programs.
Community Manager
There are two different controller drivers for that board. One Intel for the drives connected to the PCH controller and one for the Marvell controllers. Intel RST supports drives connected to the PCH controller (Intel). Verify you have connected the drive(s) to the correct SATA ports. Advanced Host Controller Interface (AHCI) is a drive communication standard and is available on both brands of controllers. AHCI has nothing to do, per say, with WHERE the drive is installed. But you must have the drive(s) connected to the PCH controller to use IRST for those drives. Drives that are connected to the Marvell controllers will use Marvell and/or Gigabyte software. (Whatever that may be.)
Here's a list of chipset supported by IRST:
http://www.intel.com/support/chipsets/imsm/sb/CS-020644.htm http://www.intel.com/support/chipsets/imsm/sb/CS-020644.htm
Community Manager
My 520 disk is connected to the SATA3 port controlled by the Intel chipset. I don't use the Marvel controller.
Bios is set to AHCI. The SSD Toolbox works perfect until I install the IRSTe ( Enterprise ) driver, as long I'm running with the standard Windows 7 driver there's no problem.
I've tried to install the normal IRST ( non enterprise ) but this is not allowed on the X79 motherboard.
After installing IRSTe the SSD drive is seen as a SCSI drive instead of a IDE and therefore no longer supported by the Toolbox.
So Intel has a problem here.
DShar11
This has been an issue since day one with the 520 series.
I think they will be dropping these E drivers all together, they seem to bring nothing but issues to the table.
I load the 11 series IRST driver thru the device manager, this gives me IRST driver with FULL Intel toolbox functionality. Ha Ha Intel, got around your silly E driver, and much better performance also, geeze who would not want that.
Community Manager
Dave: Are you also using a X79 board?
Which driver exactly did you download?
I've tested this one which works quite well.
/Detail_Desc.aspx?agr=Y&ProdId=2101&DwnldID=20913&keyword= AHCI: Intel® Rapid Storage Technology Driver for Intel Desktop Boards
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20913&ProdId=2101&lang=eng http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20913&ProdId=2101&lang=eng
File name:f6flpy-x64_11.0.0.1032.zipVersion:11.0.0.1032
And then manually selecting this one:
Intel(R) Desktop/Workstation/Server Express Chipset SATA AHCI Controller
DShar11
Yes, I am on an Asus RIVE X79, love it.
I am running the 11 series driver, the same one you linked to, just a little bit of a procedure you need to go through to get it to load.
Community Manager
I have an ASUS Rampage IV Extreme motherboard (X79) and Windows 7 Ultimate 64-bit and I was getting the same problem... the toolbox did not identify my Intel 520 drive with the Intel RST enterprise (RSTe) even with the updated driver 3.0.0.2003 (RSTe_V3002003_XPWin7) and software that I downloaded from the ASUS site. The drive said "Unknown 240GB", S.M.A.R.T. was not enabled (the SMART Summary said it could not report anything because SMART was disabled), and I couldn't run the optimizer. Plus I was also getting really poor performance, and system hangs under heavy load (with 4 threads copying files to the drive, or deleting files from the drive, anything needing to touch the drive would freeze for 10-30 seconds at a time). And the performance was only about half of what it should have been under normal usage (it was slower than a 7,200 RPM WD black drive for my software builds).
So, after reading this article, I upgraded to the 11.0.0.1032 by going to the Device Manager -> Storage controllers -> Intel... and updated it from the link above. I installed from the f6flpy-x64_11.0.0.1032 archive, from the iaAHCI.inf file, and selected the "Intel(R) Desktop/Workstation/Server Express Chipset SATA RAID Controller" and it installed correctly. After rebooting the toolbox works great and the drive performance was better... still a few hangs but only for a second or less at a time. However, now my Intel RSTe software no longer works. I get an error message from the Intel Rapid Storage Technology enterprise (RSTe) program IAStoreUI.exe:
Window Title: Intel Rapid Storage Technology enterprise
Error Message: An unknown error occurred while running this application. If the problem persists, please restart your computer or try reinstalling the application.
I'm guessing this is because the RST enterprise (or RSTe) software is not compatible with the regular (non-enterprise) RST 11.0.0.1032 drivers. However, when I try to run the software install to install the regular RST software, STOR_Vista_Win7_11.0.0.1032_PV, I get an error message from Setup.exe:
Window Title: Error
Error Message: This computer does not meet the minimum requirements for installing the software.
So, it appears I have my choice of having either the Intel RSTe drivers and software that works but with really poor performance and no toolbox, or use the RST 11 drivers and have the toolbox work and good performance but the RST software not working.
Thoughts?
I would hoping we will either get a version of the RST 11 drivers that work with the X79, or they'll port all the fixes/changes from the 11 drivers over to the RSTe drivers. Does anyone from Intel have an idea on what the plan is? The RSTe 3.0.0.2003 drivers are really unusable in their current state... makes the SSD slower than a traditional hard drives and those 10-30 freezes are unbearable: we all know Windows is really bad when the drive freezes (lots of programs just hang up and don't respond to anything while the drive is hung).
-J.C.
DShar11
You are 100% correct sir, you have to choose whcih you want, Intel says we cannot have both working at the same time, at least not yet, lol.
But with performance so much better with the 11 series it's no contest really. When I rarely need to do something with the IRST CP I just reinstall the E driver, do what I must and then go back to the 11 series.
Community Manager
Well I was skeptical and more cautious than need be by waiting to load the V11 drivers. While I am pleased the drivers information shared works well I am disappointed with Intel. It is a shame considering the research, time, and money spent before building my latest machine only to find to "almost" make it work as advertised a workaround needed to be used. I appreciate many times we do what is needed to get the results we want, but really...Extreme board with server chipset top of line line hex core, latest 240GB drive and I need to roll back to a driver not even supported by Intel.
OK I'm done.
Thank you Dave, Parsec, and others for contributing to this thread and being patient with my reluctance.
Community Manager
How did you guys manage to install the 11.0.0.1032 driver?
I have a Gigabyte X79-UD5 board with an Intel 520 180GB SSD; and the
only drivers (Win 7 64 bit) I can install are the generic Windows driver (in
which SMART features are enabled and the toolbox works fine), and the
"Intel C600 Series Chipset SATA AHCI Controller" driver 3.1.0.1085 (from
April 24 2012) in which SMART is disabled.
If I point the device manager to the folder containing the 11.0.0.1032 driver, Windows
simply refuses to install it as an upgrade to either the generic windows
driver or the recent AHCI driver.
Any help much appreciated...
Ulvi
Community Manager
You will get a warning message stating the device driver is not recommended because windows cannot verify that it is compatible with your hardware and a question do you want to continue installing this driver? select yes and restart. Trust me it works. And if you want to change back let windows intall the driver automatically then restart
Community Manager
I don't get the warning message; instead windows simply says "you already have the
best driver installed" (I'm paraphrasing), and refuses to install the update or give me the
option to decide what is best
Is there a way to overrride this behavior?
thx
Community Manager
@ J.C.***Your detailed instructions did indeed solve the problem of Intel SSD Optimizer being grayed out. It is necessary to do the install "the long way", i.e. have disk, so you can point right to the iaACHI.inf file. Just saying upgrade the driver doesn't do it. Thanks for the write up.
@D749***I'm with you!!
PPapp
It's been how many months now and Intel has still not addressed this issue?!?!
DSane
The problem finally seems to be fixed with the latest RSTe driver version 3.2.0.1135 from about a week ago. I experienced the same problems discussed in this thread (Gigabyte GA-X79-UD3, Intel 330 180GB), and they were fixed after downloading and installing that new version of the driver. The RSTe GUI now correctly reports that the storage controller works in AHCI mode, the Intel SSD Toolbox recognises my SSD and all its features seem to work.
Community Manager
Thanks for the heads up. Latest RSTe driver version, which really shows as 3.2.0.1126 when unpacked, seems to indeed work. I am not, however, using a RAID setup but I can tell you that even with a single SSD (C), the grayed out problem is gone. Also, from the ASUS Republic of Gamers comes this info:
Run Command Prompt with as administrator) and enter the follow command.
fsutil behavior query DisableDeleteNotify
If the result is '0' TRIM is enabled.
Did it and got 0 so hopefully further confirmation of solution. BTW, this is on ASUS P9X79 pro MBO.
DSane
Just checked my installation, you are right, mine reports as 3.2.0.1126 as well. Glad to hear your SSD is now detected as well.
S.M.A.R.T. and the SSD Toolbox are, as far as I know by design, still not supported if the storage controller runs in RAID mode. I don't know if there are controllers that support TRIM for RAID configurations of SSDs, but I hear it's quite an involved problem.
The fsutil parameter check determines whether Windows 7 is configured to issue TRIM commands to SSDs, but unfortunately does not help in determining whether the driver successfully receives and forwards them to the drive. My system reported '0' even though my SSD was not detected as such (it was listed in the automatic defragmentation schedule, which Windows doesn't do if it recognises an SSD). The most definite proof that everything works is probably when the Intel SSD Toolbox successfully reports health and status of the drive.
Community Manager
