Community
cancel
Showing results for
Search instead for
Did you mean:
nhora
are these speeds normal for 600p ?
Jump to solution
I got a 1TB intel 600p steam drive and did a bunch of benchmarks on it, they seem fine i guess, but i was expecting games to load much faster, and they don't really.
https://postimg.cc/gallery/1uqlutlju/
On my secondary monitor i have task manager running with this disk selected to see read writes etc and when games load i rarely see anything above 280MB/s reads. i mean older sata ssds do better, is this normal ?
specs: win 10 64bit, ryzen 2700x, asrock x470 taichi, gskill 3200mhz cl14 ddr4, rtx 2080, 2 sata ssds 1 hdd, 1 nvme ssd
Vegan
Looking at your results suggests your SSD is working properly.
You might want to use the Intel SSD toolkit which can help maintain your SSD
Santiago_A_Intel
Hi nhora,
Thank you for contacting Intel® SSD support group with your request for assistance with your Intel® SSD 660p Series.
Since we don’t have sufficient details about your system, we are requiring with your cooperation to provide us with some information about it. To do this, Intel® has available, the Intel® System Support Utility for Windows*; you’ll be able to download it on the following link: https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-
·        Please download the software.
·        When finished downloading it, open it and follow instructions
·        Please attach the SSU Log text file obtained on your next your reply.
To help you further with your request, It will be very helpful to receive from you, a screenshot of the “Disk Management” of windows, showing all your HDDs and partitions.
Please let us know if you might need additional support with your SSD.
We will be looking forward to your reply.
Santiago A.
Under Contract to Intel Corporation
Vegan
Santiago_A_Intel
Hi nhora,
Greetings from Intel® SSD support group.
Community member Vegan came with an accurate reply to your enquiry regarding the current specifications on your Intel® SSD 660p Series 1.0TB, M.2 80mm PCIe 3.0 x4, 3D2, QLC drive.
For additional details, please refer to the following link with full specification on this unit: https://ark.intel.com/content/www/us/en/ark/products/149407/intel-ssd-660p-series-1-0tb-m-2-80mm-pci...
Vegan’s answer will be selected as best reply.
Santiago A.
