cancel
Showing results for
Search instead for
Did you mean:
compatabilty advise
Esteemed Contributor III
hello,can you help,
which SSD would be compatable with the Intel dx58s0 motherboard.and a i7980x(6 core)extreme processor
which graphic card to use
which sound card to use
which are compatable.
whether to use three dddr3 memory cards or one.
as you can see I do not really know much,
so need your help.
thanks,dave.
1 REPLY 1
To answer your questions, in their order:
Any one.
Whatever fits your budget, and is PCI-E 16x compatible, which would be most of them.
Don't need one, onboard audio is fine.
On the Intel mother board you mention, you can use one, two, or three cards, but oddly that 'board does not support triple channel mode (three cards.)
