Community
cancel
Showing results for
Search instead for
Did you mean:
matt
difference between SSDSC2BX200G401 and SSDSC2BX200G4K1
 any difference between SSDSC2BX200G401 and  SSDSC2BX200G4K1
JosafathB_Intel
Hello matt, Thank you for contacting Intel® Technical Support. As we understand, you need assistance regarding an Intel® SSD DC S3610 Series. If we infer correctly, please take into consideration the information below: • Based on https://ark.intel.com/products/86640/Intel-SSD-DC-S3610-Series-200GB-2-5in-SATA-6Gb-s-20nm-MLC-?q=SS... The Intel® SSD DC S3610 Series has different ordering codes because some of them belong to OEM (HP,Dell,etc) and may have a different firmware that the SSDSC2BX200G401. • All the Intel® SSD DC S3610 Series (200GB, 2.5in SATA 6Gb/s, 20nm, MLC) have the same specifications. We hope you find this information helpful. If you need further assistance please do not hesitate to contact us again Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello matt, Thank you for having contacted Intel® Technical Support. I was reviewing your community post and we would like to know if you need further assistance or if we can close this case. We will be looking forward to your reply. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
JosafathB_Intel
Hello matt, Thank you for contacting Intel® Memory & Storage Support. This is just a friendly reminder that your case remains open. Should you need our technical assistance please do not hesitate to contact us back. Best regards, Josh B. Intel® Customer Support Technician Under Contract to Intel Corporation
