Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
falla en disco duro
MarcoNegrete
No puedo acceder a mi disco duro me aparece como disk array como lo soluciono apoyenme
n_scott_pearson
Please explain yourself better, providing every detail that you can.
As well, please download and run the Intel System Support Utility for Windows. Select all data categories and then have it generate a report. Next, have the tool Save the report to a text file (don't try to use the Submit capability; it doesn't work). Finally, using the Drag and drop here or browse files to attach dialog below the edit box for the body of your response post, upload and attach this file to the response post.
