Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
firmware update with 2 drives in raid
I just tried to update my firmware with the latest available from intel. I created the CD and shutdown the computer and booted to the CD. The update CD runs and spits back the message, "no drives found". They are currently configured to be in raid 0. Do I need to remove them from raid before this will work?
Andrew
Community Manager
yes - remove them from RAID and try again. You should first try AHCI mode, then IDE if unsuccessful.
DZand
Valued Contributor I
Just do the following:
1. Enter the BIOS and set the SATA Controllers from "RAID" to "IDE" Mode (don't choose the "AHCI" Mode). Save the BIOS settings and reboot.
2. Boot off the SSD Firmware CD and flash the new Firmware onto both SSD's. The Firmware installer will find them.
3. Reboot again off the SSD Firmware CD just to let it certify, that the Firmware of both SSD's have been successfully updated.
4. Reboot, enter the BIOS and set the SATA Controllers back from "IDE" to "RAID" Mode. Save the BIOS settings and reboot.
5. Have fun with your RAID again.
Fernando
Community Manager
Fernando,
Thanks for the tip I will give it a whirl. I am a little concerned that I will screw up the data on my disks. Will I be able to boot my OS again once I change them back to RAID?
Andrew
Community Manager
Sorry to bring back such an old thread. However I have the exact same question as the topic started and I wondered if he or someone else can confirm the method suggested by Fernando is indeed safe.
Community Manager
Yes this should work. I've tried it myself.....however you should always back up your data before you update firmware no matter what mode you are running in.
