cancel
Showing results for
Search instead for
Did you mean:
horrible results in x25-m...
Esteemed Contributor III
I went through different posts, but cant see a solution.
Just bought a new motherboard and Athlon, put SSD in AHCI mode with Win7. My results:
Sata2, Win7 Home, disabled defrag, superfetch
17 REPLIES 17
Can you provide an AS SSD benchmark of your C: drive running in Windows Safe Mode?
Here is a banchmark from Windows Safe Mode... Almost the same results...
From what I see it look like the only problem is heavy NTFS file system overhead. If you are interested I could write you a cleanup checklist that will take care of that.
It's going to be the AMD SATA controller. If possible try the drive in a system with an Intel ICH9 or ICH10 controller. You should then see better benchmark results.
Stopping light background process will make zero difference, as you found out by running in safe mode. That's the bad news; the good news is that outside of benchmarking you will most likely not notice any difference.
(EDIT: I'm not sure if the SB710 passes the trim command or not. If not, are you running the Intel SSD Toolbox Optimizer?
Thanks to ALL of you guys! yes, i was worried, but I guess will not see the difference in every day work.
I also tried ATTO benchmark and it looks 10% slower than other results, so... will just leave it.
I was told I dont neew Intel toolbox for optimizing as I use Win7, but just in case I ran it last week
