cancel
Showing results for
Search instead for
Did you mean:
how to connect p4510 u.2 2.5 inch to hp DL9 g6 servers
hessam_jafarzad
New Contributor
hi , we bought 2 pcs intel p4510 2.5 inch u.2 F/F and we need to connect them to our servers ( hp DL9 g6 ) . please guide us , which connector we should use
1 ACCEPTED SOLUTION
JosafathB_Intel
Valued Contributor
Hello hessam_jafarzadeh,
Thank you for contacting Intel® Memory and Storage support.
As we understand, you need assistance related to your HP ProLiant DL380 G6 Server, specifically, on how to connect an Intel® SSD DC P4510 Series to your system. If we inferred correctly review the following information:
- We advise you to contact your server original equipment manufacturer (OEM) Hewlett Packard Enterprise* to get further information and assistance about compatible hardware and the recommended configuration.
- Based on your OEM website, we do not see this SSDs as compatibles:
https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=c00305257
We advise you to check with your OEM to confirm compatibility.
We will proceed to close this inquiry now.
If you need assistance related to an Intel® product, please post a new question.
Josh B.
A Contingent Worker at Intel®
1 REPLY 1
JosafathB_Intel
Valued Contributor
Josh B.
