Community
cancel
Showing results for
Search instead for
Did you mean:
Othman_B_Intel
how to plug multiple SSD PCIe NVMe 2.5" in a server?
Jump to solution
I would like to install 8 SSDs PCIe NVMe x4 (like Intel SSD DC P4501 Series). It has a form factor 2.5".
I am looking for a PCIe card with many SFF 8643 connectors, ideally a PCIe x16 with 4 SFF 8643 connectors. Is there such device ?
Regards.
Community Manager
Hello Othman_B,
We understand you would like to know how to plug several SSDs PCIe NVMe* 2.5" in a server, for you to be aware, you can do that by using a backplane NVME* module.
For this, we do recommend you contacting your server manufacturer as they could point you to a compatible device and at the same time, ask if the SSD you want to use will work with both.
Please let us know if you need more assistance.
Nestor C
Community Manager
Hello Othman_B,
Nestor C
Othman_B_Intel
Hello Nestor,
Thanks for the advice. I'll have a look at the backplane module.
Othman.
Community Manager
Hi Othman_B,
You are welcome. Let us know in case you need further assistance.
Nestor C
Othman_B_Intel
I found the answer. These cards can manage 4 or 8 SSD PCIe NVMe:
https://ark.intel.com/products/93477/Full-height-Low-profile-PCIe-Switch-Add-in-Card-supporting-4x-N... Full-height, Low-profile PCIe* Switch Add-in Card supporting 4x NVMe* SSD AXX4PX8HDAIC Product Specifications https://ark.intel.com/products/93477/Full-height-Low-profile-PCIe-Switch-Add-in-Card-supporting-4x-N... https://ark.intel.com/products/93477/Full-height-Low-profile-PCIe-Switch-Add-in-Card-supporting-4x-N...
https://ark.intel.com/products/124459/8-Port-PCIe-Gen3-x8-Switch-AIC-AXXP3SWX08080 8-Port PCIe Gen3 x8 Switch AIC AXXP3SWX08080 Product Specifications
Moreover, the tri-mode RAID controller can also manage SSD PCIe NVMe. For example:
https://www.intel.com/content/www/us/en/servers/raid/raid-adapter-rsp3td160f.html Intel® RAID Adapter RSP3TD160F
