Community
cancel
Showing results for
Search instead for
Did you mean:
SLim9
iEMT/iOMT result still valid/true if there is a redriver chip between the host and SATA/NVMe interface?
Jump to solution
Hi, may I know if the Intel Electrical Margin Tool (iEMT) or Intel IO Margin Tool (iOMT) result is valid if there is a redriver (also known as repeater IC, regenerates signals to boost the signal quality of high-speed interfaces) between the host and the SATA/NVMe interface?
Will iEMT/iOMT result be 'affected' with the redriver?
Santiago_A_Intel
Hello SLim9,
Thank you for your contact to Intel® SSD Support Group with your request for support.
We have received a reply from our upper support level, they have indicated you must contact your Intel® Field Applications Engineer (FAE) for this kind of subject, since this is not to be handled in our communities forum; might your company does not have one, you are requested to reach your local distributor to get one assigned. This information, as indicated above, is restricted and cannot be disclosed publicly.
To reach our worldwide distributors network, please follow this link and select your country to get the information available for your region: https://www.intel.com/content/www/us/en/partner/where-to-buy/overview.html
With this reply, we want to let you know this case is being closed.
Please feel free to get back to Intel® communities, whenever you might feel necessary.
Santiago A.
Under Contract to Intel Corporation
Santiago_A_Intel
Hello SLim9,
We’ve analyzed your inquiry and it might be needing some additional research and additional contact with our engineering department; for this reason, we will be escalating this case to our higher support level.
Please notice, due to the nature of this process, at this point, we are not able to provide a time frame for resolution (ETA). This process depends on the queue. However, we will keep you in the loop as the situation develops. Also, feel free to request updates as you deem convenient.
Please don’t hesitate to contact us in case you might have any additional inquires.
Santiago A.
Santiago_A_Intel
Hello SLim9,
Santiago A.
