cancel
Showing results for
Search instead for
Did you mean:
if fsutil... disabledeletenotify =0, is toolbox needed?
Esteemed Contributor III
query disabledeletenotify returns 0 so do I need to use the Toolbox software for anything? I ask because I get an error with the Toolbox. Something about the utility doesn't work with RAID even though I am not using RAID. I have a single SSD. However I am using AMD's AHCI driver amdsata.sys so I am assuming that why's I get the RAID error? The toolbox is only compatible with MS's AHCI driver and RST?
If query disabledeletenotify returns 0, does this mean my computer is all set with trim? I am using Windows 7.
4 REPLIES 4
The fsutil behavior query disabledeletenotify only informs you that the OS is sending the TRIM command to the hard drive. It does not mean that the command is being received by the SSD. If the controller cannot pass the OS TRIM command the SSD does not receive it.
How do I know the SSD received it and executed it successfully?
Since you are using the AMD drivers, TRIM is not being passed to your SSD.
I rolled back to Microsoft's driver.
