Community
cancel
Showing results for
Search instead for
Did you mean:
dlawr1
intel 600p gen3 ssd 256gb compatibility
This is probably a really silly question, but I purchased an Intel 256gb 600p gen3 m.2 ssd to slot in an Asus hyper mini x 4 pcie adapter. can I run this on a pcie x 4 slot on an AMD platform?
Community Manager
Hello Dionlouvain,
We understand you would like to use the SSD with an Asus Hyper Mini x4 PCIe adapter.
Checking the https://www.asus.com/us/Motherboard-Accessory/HYPER_M2_X4_MINI_CARD/specifications/ specs of the adapter, we can tell it should work without a problem. The only thing you need to double check is if the motherboard does support booting from the PCIe* slot (in case you want to use it as a boot drive).
Please let us know if you need further assistance.
Nestor C
Community Manager
Hello Dionlouvain,
We are wondering if you were able to read our previous post and if you need further assistance. We'll be waiting for your response.
Nestor C
