cancel
Showing results for
Search instead for
Did you mean:
intel 730 ssd 240gb
JD6
New Contributor
Alright so i have an alienware aurora r4 - 2012, the harddrive got old so i decided to buy an SSD, so i plugged it in and everything it showed up on bios but when i tried installing OS on it it didn't show up anyway to fix this?
6 REPLIES 6
ppara5
Contributor
Did you put a partition on it? Do you have a second set of SATA cables to try? Did you try a different SATA port?
JD6
New Contributor
I tried paritioning it but i'm not sure if i did it correctly, also there's no sata cables theres just a spot to push the drive in, and tried all 3 slots
The problem is that you still have multiple variables. You cannot distinguish between the drive and the connections because either could be the problem. Do you have another PC to which you could connect the SSD? If you can do that and write some files to it, then the suspect looks more like the connectors and/or motherboard on the original PC. And if you can write files to it, then you must have created a proper partition on it.
By the way, I have an Intel 730 240 GB SSD. I have secure-erased the contents and reinstalled W-7 a few times and it continues to work perfectly. I think the 730 is a great drive and I wish Intel would make another batch.
Esteemed Contributor III
FierCe,
We understand the OS cannot be installed in your system, however you informed that the SSD is fully detected in BIOS. What we can recommend is to have the latest driver for Intel® Rapid Storage Technology, this driver needs to be extracted in any USB flash drive (No folder created) and as soon as you have the "Where do you want to install Windows" screen open, click on browse to have this driver installed, that should detect your SSD.
Please find the driver here, from the Dell's support page: http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=K12GR&fileId=3398050545&os... http://www.dell.com/support/home/us/en/19/Drivers/DriversDetails?driverId=K12GR&fileId=3398050545&os...
Please let us know if you need any more help from us.
