cancel
Showing results for
Search instead for
Did you mean:
intel 750 low read speed after new FW
OMurí
New Contributor II
Hello, I have SSD 750 800GB U.2 port - SSDPE2MW800G4X1
I had great speed about 2200MB/s (read)..... when I install SSD Toolbox 3.4.0 and update firmware + restart I have maximum speed (read) about 800MB for now 😞 - drivers and everything are the same
does anyone have the same experience? Can I get back previous firmware?
Thank you
13 REPLIES 13
Esteemed Contributor III
Hello GEQ,
Based on the screenshots provided, we can noticed that the test count is different. We would like you to please share a screenshot where the test count is 5, as 5 would be the default setting and also the setting you used to run when the old firmware was installed.Please let us know.Regards,NC
OMurí
New Contributor II
Hi, as you wish, but this isn´t solution for my problem...
Hello GEQ,
We will be checking this with our engineering department and we will run some tests. We will keep you posted over here.Thanks,NC
Hi GEQ,
Thanks for the patience on this matter. We will be sending you an e-mail with further information about the resolution of this case.Please let us know if you receive it.Regards,NC
