Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
intel ssd is not attached or is disabled
Getting that error while trying to update the firmware. Was there any solution to this yet? Ive tried in IDE mode and AHCI mode. And updating my bios to the latest one. I have win 7 ultimate. Just installed. Asus m4a78 pro motherboard. Thanks in advance. Oh I should mention I have the intel x25-m 80 g2.
Community Manager
Do you have an Nvidia graphics card on your machine? Check!
Community Manager
yeah its a nvidia card. 8800 gts.
Community Manager
Then forget about it! Its not going to work. I have an Nvidia card in my Mac Mini and I'm in exactly the same bullshit situation you are in. Goto the intel section where you downloaded your firmware update. There is a .PDF document. Open it and read what it says about Nvidia.
I have to now search for some old junk of a PC someplace as my current PC has an Nvidia graphics card too.
Community Manager
I could be wrong but I think it has to deal with the nvidia chipset and not the video card,
Community Manager
Ok I solved my problem. Figured I would post it in case anyone else has the same issue. Apparently the drive didnt like to be plugged into the SATA 2 port. I had to plug it into the SATA 1 port. And the firmware detected it no problem. Did this while in AHCI mode.
Although I got en error while installing the firmware which scared the shit out me. "Error reading from the drive..." However it actually did install the firmware after checking crystal disk info.
Community Manager
You are wrong, this warning is not about Nvidia graphic cards. This does only affect Nvidia mainboard chipsets.
