Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
intel ssd tolbox 3.4.0 not install
Hello! Windows 10 Pro 32-bit not install Intel SSD Toolbox 3.4.0 (3.3.7 install no problem). When installing, the computer restarts. Log in attach.
Hello Zargorsky61,
We understand you are unable to install the Intel® Solid State Drive Toolbox in your Windows® 10 Pro 32bit. We would like to let you know that it should work fine as this version of OS was tested, but checking the log file you attached, we can noticed that the failure is happening on the install of the Visual Studio 2015 redistribution package.
For that, we would like you to try the following:
-Go to the control panel and access programs and features
-Look for Visual Studio 2015, select it and click repair
Once you do that, it is highly recommended to verify if the system have the latest updates installed, by running Windows* updates.
Could you please as well provide us the full computer specs you have? (Computer brand/model, motherboard, BIOS version, SSD model, RAM, etc)
NC
Hello Zargorsky61,
NC
Thank you! The problem was in MS Visual C++ 2015 Redistributable (x86) 14.0.23026. After removing this package, Intel SSD Toolbox 3.4.0 has been successfully installed.
Hi Zargorsky61,
We are glad to hear that it worked just fine after removing the package. In case you need further assistance please let us know.
Have a nice week.
NC
