Community
cancel
Showing results for
Search instead for
Did you mean:
zsunn
intel ssd toolbox always stop working with intel 525 180G
I got a intel 525 180G installed on a laptop Clevo w740su, everytime when I start intel ssd toolbox, it always crashed.
- <</span>Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event http://schemas.microsoft.com/win/2004/08/events/event">
- <</span>System>
<</span>Provider Name="Application Error" />
<</span>EventID Qualifiers="0">1000</</span>EventID>
<</span>Level>2</</span>Level>
<</span>Task>100</</span>Task>
<</span>Keywords>0x80000000000000</</span>Keywords>
<</span>TimeCreated SystemTime="2015-05-01T04:46:35.000000000Z" />
<</span>EventRecordID>11550</</span>EventRecordID>
<</span>Channel>Application</</span>Channel>
<</span>Computer>zhufeng-x411</</span>Computer>
<</span>Security />
ystem>
- <</span>EventData> <</span>Data>Intel SSD Toolbox.exe</</span>Data>
<</span>Data>3.2.3.400</</span>Data>
<</span>Data>53c8395c</</span>Data>
<</span>Data>c0000005</</span>Data>
<span class...
ASouz7
zhuteng,
Is your SSD working properly other than this issue with the Intel® Solid-State Drive Toolbox?
zsunn
yes , the ssd works great.
I can read the SMART data with AIDA64 and everything seems to be normal.
ASouz7
Hello Zhufeg,
Have taken a look at this : http://www.intel.com/support/ssdc/hpssd/sb/CS-031221.htm Intel® High Performance Solid-State Drives — Intel® Solid-State Drive Toolbox Frequently Asked Questions
You can also clean uninstall the application and check for any possible Windows update and then reinstall it again.
Let us know if this helped you.
