Community
cancel
Showing results for
Search instead for
Did you mean:
RRago1
intel ssd toolbox
I have installed an intel ssd 320 series 160gb on a Lenovo t420 win 7 sp1 with the most current 4PC1036 firmware. it works fine. BUT I have also installed intel's ssd toolbox. now the application does what it is supposed to HOWEVER every time I start it I get 3 WMI Event id 24 errors in win 7 event viewer with the following details:
1.
Description:
Event provider IntelWLANEventProvider attempted to register query "select * from CIntelQosEvent" whose target class "CIntelQosEvent" in //./root/default namespace does not exist. The query will be ignored.
2.
Description:
Event provider IntelWLANEventProvider attempted to register query "select * from CIntelDot1xEvent" whose target class "CIntelDot1xEvent" in //./root/default namespace does not exist. The query will be ignored.
3.
Description:
Event provider IntelWLANEventProvider attempted to register query "select * from CIntelWLANEvent" whose target class "CIntelWLANEvent" in //./root/default namespace does not exist. The query will be ignored.
can anyone help correct this. I do not think ignoring it is an answer as all my win 7 machines run with 0 errors, 0 warnings and 0 critical.
jbenavides
The first thing to do is to uninstall your current version of Intel® SSD Toolbox, then go the following link to https://downloadcenter.intel.com/download/18455/Intel-Solid-State-Drive-Toolbox Download Intel® Solid-State Drive Toolbox and update to the current version 3.3.3.
If the issue persists, please make sure you have the most recent drivers for your wireless adapter which can be found in the http://www.intel.com/content/www/us/en/support/topics/oems.html Computer Manufacturer Support Websites, the generic version is also available at Intel https://downloadcenter.intel.com/ Drivers & Software.
