cancel
Showing results for
Search instead for
Did you mean:
intell 240 ssd runtime_bad_block_total
ATule
New Contributor
Good evening,
Smart self test utils show "183 runtime bad block total" = 45 , and I could not find what does it mean. Should I try to replace disk?
Could you send me any suggestion, or help with replacement of disk?
Arman
15 REPLIES 15
Esteemed Contributor III
Hello Arman2020,
We'd like to know if you were able to read our previous post and if you can share the file with us. We'll be waiting for your response.Regards,Nestor C
ATule
New Contributor
Good morning,
Thank you for the help, as computer with Windows I have in another place, I could get requested data only when I will have permission. Hope today I could complete your request.
Thank you once more.
ATule
New Contributor
Good evening,
Please find required data in attached file
Hi Arman2020,
Based on the file attached, we don't see any problems with the SSD. In fact, the SSD is very healthy, it does not show errors at all or any indication of wearing out.So, we can tell you that the SSD is running fine and also healthy, no need to worry about it.Regards,Nestor C
ATule
New Contributor
Good evening,
Thank you very much
