cancel
Showing results for
Search instead for
Did you mean:
is SSDPEKKW512G8XT SSD compatible for MCI B350 PC Mate motherboard?
DTele
New Contributor
thank you in advance for your answer!@
2 REPLIES 2
Esteemed Contributor III
Hello TelSanin,
Thanks for posting in our communities. This thread has been moved to our Solid State Drive sub-forum. We understand that you would like to confirm https://ark.intel.com/products/134582/Intel-SSD-760p-Series-512GB-M_2-80mm-PCIe-3_0-x4-3D2-TLC SSDPEKKW512G8XT compatibility with an specific motherboard.The Intel® SSD 760p Series has not been validated on MSI B350 PC MATE* from our side. However, the motherboard has the required M.2 M Key PCIe NVMe slot to be used with this drive and according to MSI* documentation, the https://www.msi.com/Motherboard/support/B350-PC-MATE# support-hdd motherboard is compatible with other M.2 PCIe NVMe drives.We recommend to contact the https://www.msi.com/support/ motherboard manufacturer to confirm compatibility. For a list of Intel tested motherboards, please check the following site:- http://compatibleproducts.intel.com/ProductDetails%3FactiveModule%3DMemory%2520and%2520Storage%23 Intel® Product Compatibility ToolIf you would like to know more about Intel® SSD 760p Series, please check its FAQ:- https://www.intel.com/content/www/us/en/support/articles/000026488/memory-and-storage.html Frequently Asked Questions for Intel® SSD 760p / Pro 7600p SeriesPlease let us know if there's anything else we can do for you.Best regards,Eugenio F.
DTele
New Contributor
Dear Eugenio,
thank you very much!
