Community
cancel
Showing results for
Search instead for
Did you mean:
BRoth1
isdct 2.3.0 works and isdct 2.3.1 does not - Ubuntu 14.04.4 LTS 64-bit
Jump to solution
Hello!
Following situation:
I have a system running Ubuntu 14.04.4 64-bit and a Intel DC S3500 SSD, model SSDSC2BB480G4
Intel SSD Datacenter Tool version 2.3.0 (installed from rpm) does work fine and shows the SSD (command "isdct show -a -intelssd 0")
Now with the newer version 2.3.1 of the tool, the previously working command fails with following message:
# isdct show -a -intelssd 0
Error: Invalid drive selection. Drive could not be found.
# isdct version
- Version Information -
Name: Intel(R) Data Center Tool
Version: 2.3.1
Description: Interact and configure Intel SSDs.
What could possibly go wrong here?
Bernhard
Community Manager
bernroth-itk,
We have recently released the version 3.0.0 of the Intel® Solid State Drive Data Center Tool found in this link https://downloadcenter.intel.com/download/23931/Intel-Solid-State-Drive-Data-Center-Tool Download Intel® Solid State Drive Data Center Tool Please let us know if this will work for you.
Community Manager
bernroth-itk,
We are going to reproduce your issue and perform some tests, We will get back to you as soon as possible, please let us know if you have any more questions or doubts.
Community Manager
bernroth-itk,
BRoth1
Hello Nestor!
The new tool now works without problems, thank you very much!
Do you know what actually caused that problem?
Are you planning to release a isdct tool for Solaris x86 as well?
Bernhard
Community Manager
bernroth-itk,
We have researched about this and there are no news or discussions on releasing the software for Solaris x86, at least for this month/year.
About the problem with previous software, it may be possible that the software required to be updated to work properly.
