Community
cancel
Showing results for
Search instead for
Did you mean:
NHill5
issdfut_2.0.13 failing during update
I burned https://downloadcenter.intel.com/Detail_Desc.aspx?DwnldID=18363 issdfut_2.0.13 to a CD over the weekend to update my 320 series SSD. I was able to boot from the CD and the update tool showed that my firmware did need to be updated. After I clicked update the following appeared on the screen and wouldn't go away. I tried multiple times, but always with the same result. I'm on a mid-2009 Macbook Pro.
It seems like others are having the same /message/245766# 245766 issue (bottom of page).
Would it be possible to get an ETA on a fix, or a link to the prior version(s) to try out? Thanks!
Kevin_M_Intel
Hello MrButterworth,
Thank you for all the information.
Can please try re burning the FUT? Also we have tested from our side and it worked doing a bootable USB drive.
Kevin M
