Community
cancel
Showing results for
Search instead for
Did you mean:
GH000
issdfut_64_3.0.7.iso: Failed to load ldlinux.c32
Jump to solution
I have tried t this image SSD Firmware Update iso image with cdrom/dvd rw/usbstick and qemu. All have resulted in the same error. (see screenhot)Bildschirmfoto_2019-08-16_09-35-51.pngScreenshot is from qemu test. Used command:
# qemu-system-x86_64 -cdrom issdfut_64_3.0.7.iso
JosafathB_Intel
Hello MKauf4,
Thank you for your reply.
We tried to reproduce the issue that you are reporting in our lab, in our case, we were able to successfully create a bootable CD using the ISO file included in the FUT download (https://downloadcenter.intel.com/download/28749/Intel-SSD-Firmware-Update-Tool?product=80097) using the Windows pre-built option.
We are glad to hear that you were able to use Unetbooting to create a USB bootable media.
 If you need further assistance please do not hesitate to contact us again.
Josh B.
A Contingent Worker at Intel
JosafathB_Intel
Hello GH000,
Thank you for contacting Intel® Memory & Storage Support.
As we understand, you need assistance regarding the Intel® SSD Firmware Update Tool, if we infer correctly, please review the information below:
·    The Intel® SSD Firmware Update Tool is not recommended to be used with any hypervisor or virtualization environment. This because unknown issues may occur like the one you are reporting.
·    Instead we recommend you boot you PC from the USB/DVD or CD directly and to update your SSD firmware.
 Please let us know the SSD product that you need to update the firmware this to provide you with further support.
We hope you find this information helpful.
Have a nice day.
Josh B.
GH000
Hello Josh,
Thank you for your answer.
Yes the file issdfut_64_3.0.7.iso is the Intel® SSD Firmware Update Tool which I would like to apply to my SSD:
INTEL SSDSA2M080G2GC, S/N:CVPO008600MT080BGN, WWN:5-001517-9591e25b6, FW:2CV102HD, 80.0 GB
I am running Debian 9 and I do not have Windows.
As I mentioned in my post I tried already to burn this iso image to CD and DVD-RW (using Brasero) and an USB Stick (using isohybrid and dd) . All variants gave the same error "Failed to load ldlinux.c32" while booting.
For further testing I also tested it with qemu as described wich also produced the exact same error and enabled me to make the screenshot.
JosafathB_Intel
Hello GH000,
We are going to be working on reviewing your inquiry and on trying to reproduce your issue. We will be contacting you back as soon as we have an update or in case further information is required.
 Thank you for your patience and understanding.
Josh B.
JosafathB_Intel
Hello GH000,
Thank you for your patience.
To create a bootable USB drive in to run the Intel® SSD Firmware Update Tool (FUT) on Linux we advise you to follow the steps below:
Download the latest version of the Intel® SSD Firmware Update Tool from this link:
Unzip the file and have the ISO file in an easy to find location.
Visit the following website to download the “UNetbootin” for Linux binaries:
https://unetbootin.github.io/linux_download.html
Please follow the instructions provided on this website:
To run these binaries, download them and run the command chmod +x ./unetbootin-linux, or go to Properties->Permissions and check "Execute"), then start the application by running ./unetbootin-linux
Take into consideration that it may need some other binaries like “https://pkgs.org/download/p7zip” previously installed in your system to work properly.
Please check the following screenshot as a reference of the configuration that you need to set up.
We advise you to run this application as administrator.
1. Choose the “Diskimage” option.
2. Select the “Floppy” option.
3. Select the location of the FUT ISO file.
4. Select the USB drive.
5. Click OK.
Bear in mind that this process will take from minutes to hours depending on your software and hardware configuration.
If you have future questions, please don’t hesitate to contact us. We will be more than happy to help you in any way we can.
Josh B.
Third-Party Content: Web Sites and Materials may contain user or third party submitted content; such content is not reviewed, approved or endorsed by Intel and is provided solely as a convenience to our customers and users. Under no circumstances will Intel be liable in any way for any third party submitted or provided content, including, but not limited to, any errors or omissions, or damages of any kind. ANY MATERIAL DOWNLOADED OR OTHERWISE OBTAINED THROUGH THE USE OF THE MATERIALS IS DONE AT YOUR OWN DISCRETION AND RISK AND THAT YOU WILL BE SOLELY RESPONSIBLE FOR ANY DAMAGE TO YOUR COMPUTER SYSTEM OR OTHER DEVICE OR LOSS OF DATA THAT RESULTS FROM THE DOWNLOAD OF ANY SUCH MATERIAL. By your use, you agree that you must evaluate, and bear all risks associated with, the use of any third-party content, including any reliance on the accuracy, completeness, or usefulness of such content. All postings and use of the Web Sites or Material are subject to these Terms of Use and any other program and site-specific terms.
GH000
Thank you for you answer. I did what you desribed but ufotunatly the error is the same:
JosafathB_Intel
Hello GH000,
To further assist you we have the following recommendations:
1.      Please download a new copy of the Intel® SSD Firmware Update Tool from this link:
And use the “P7zip” tool or a similar app to unzip the file.
2.      We advise you to run this application as administrator.
3.      Try to use a different USB thumb drive to create the bootable media.
We have tested the shared process in different Linux distributions and we did not experience the problem that you are reporting.
Please let us know the results after following our recommendations.
Josh B.
GH000
Thank you for your information.
I will try again next week with a different USB Stick.
GH000
I tried it with another usb stick FAT32 formatted. Unfortunately the same error.
I ran unetbootin-linux64-661.bin as root took the issdfut_64_3.0.7.iso from a new download with the settings like my screenshot.
Did you test this under Debian 9?
Unfortunatly I do not have Windows.
JosafathB_Intel
Hello GH000,
Thank you for having contacted Intel® Memory & Storage Support.
This is just a friendly reminder that your case remains open.
Should you need our technical assistance please do not hesitate to contact us back.
Josh B.
JosafathB_Intel
Hello GH000,
We will be looking forward to your reply letting us know the results.
Josh B.
MKauf4
I have the same issue.
I used Windows to simply burn the ISO image to a CD and boot it.
I assume this is the basic usage and should work without addidional preprocessing.
But it always fails with this, on every computer, regardless of boot mode settinge.
MKauf4
Well, I succeeded by creating a bootable USB medium with UNetbootin in Windows.
But it should be cleary stated that the image can't be simply burnt to a CD.
JosafathB_Intel
Hello MKauf4,
Josh B.
JosafathB_Intel
Hello GH000,
This process was tested using different versions of Linux like Ubuntu, Suse, etc.
We did test this process in Debian 9, we did not notice any difference between the distributions based on Debian and Debian 9 the tool worked as expected as SU.
We hope you find this information useful.
Josh B.
GH000
Thank you for your help.
Unfortunately I run out of ideas what to try next.
I would love to have a plain, simple, stupid, standardized ISO file without any dependency to some obscure external copying / burning tool that is not part of standard distributions. Better tough to have a ISO hybrid image that can be bitwise copied to USB (for example with simple dd) or burned to CD with every burning software on this planet. Debian does this with their installation CD's and I was copying CD's and USB sticks for years on different plattforms without any issue.
https://www.debian.org/releases/stretch/amd64/ch04s03.html.en
JosafathB_Intel
Hello GH000,
We understand that this process can be frustrating, but since we already tried several options to create the bootable media from your OS and doesn’t work as expected. Our recommendation will be to try to get another system with Windows* and create the bootable media using Rufus (https://rufus.ie/) or to connect your SSD to a system with Windows to update the firmware using the Intel® Solid State Drive Toolbox (https://downloadcenter.intel.com/download/28808/Intel-Solid-State-Drive-Toolbox?product=80096).
Thank you for your feedback, we will provide it to the department in charge of developing the tool to be taken into consideration for future releases.
Josh B.
FMook
I just ran into this specific problem myself on a specific computer, using the same 3.0.7 bootable CD I've been using. Not sure what's different about this PC, but I was able to work around the problem by having the CD boot in UEFI mode. Same problem occurs with the 3.0.8 CD as well.
