Community
cancel
Showing results for
Search instead for
Did you mean:
PTiel
latest isdct 2.2.3 won't show NVMe P3600 drive
Just installed a P3600 NVMe 2.5" drive. The drive shows up correctly, with no issues, and handles I/O within windows just fine.
However, if I try to run the isdct app, with isdct -show intelssd it *only* shows the two standard Intel SSDs in the system (Raid 0 DC S3700s), and NOT the P3600 NVMe drive.
I assume this is a bug? If so, when can we get a fix?
Community Manager
Proteus7:
What OS?
I expect your running Windows* and the answer is that you are using the built in NVMe driver but for Intel DataCenter tool to recognize the drive the Intel NVMe driver is needed.
https://downloadcenter.intel.com/download/23929/Intel-Solid-State-Drive-Data-Center-Family-for-PCIe-... Intel® Download Center
PTiel
Running Windows 8.1, and I already installed the latest Intel NVMe driver (shows as Intel Solid-State Drive P3700/P3600/P3500/750 series) 1.2.0.1002, date 2/4/2015
Has this been tested with both regular Intel SSDs and NVMe SSDs installed? I'm guessing thats the issue here, unfortunately OS is installed on the regular SSDs so I can't remove them.
Community Manager
It should work fine with SATA based SSD and SSD P3600. I'm currently using an add in card SSD 750 (NVMe) and SSD 730 is the boot drive. I would expect your configuration to work the same.
Can you provide the motherboard model, bios and how the SSD P3600 is connected? ie. using an HBA or cable model ___ and what is the controller.
Possibly load SSD toolbox and export the boot drive info? Maybe it will show the SSD 750 and you can export that also...
PTiel
It does not. Note that the SSD P3600 works just fine, is formatted and seen by the OS, and has reliable I/O. So the system clearly sees the drive, its just the isdct tool that does not. Also note that in my case, the boot drives are a pair in RAID0.
Interestingly enough, SSDtoolbox does see the drive (and shows firmware 8DV1ND01). Its just the isdct tool that only shows the S3700 drives, but not this one. Unfortunately, isdct is the tool needed to manage and update P3600 nvme drives....
PTiel
Further information:
The P3600 is connected to an Asus X99 Deluxe with Hyper-Kit and the NVMe cable from the SSD 750 drive. Note that the drive works flawlessly. The issue is specifically with the ISDCT application being unable to see the drive, when a RAID0 SSD is also configured in the system. Can we get an update on when this can be repro'd and fixed please?
Community Manager
Proteus7,
I believe this drive is using OEM firmware and that is why it is not detected with the DataCenter Tool. Can you please take a photo of the top label of the drive (With S/N etc.)
Community Manager
This may be easier. Can you select the drive in Intel(R) SSD Toolbox. Then export and share the .csv - I like to confirm the model details.
