cancel
Showing results for
Search instead for
Did you mean:
low score on 750 ssd
aamit1
New Contributor
Hi, i installed the 750 PCIe
MB is asus z 170 pro
The SSD connected to the PICE slot at the bottom. the last one. in intel TOOL BOX it says:
Current PCIe Link Speed 0x3
Negotiated PCIe Link Width 0x4
Windows 7 64, 32RAM, 1000 crossairPS, MSI GTX 770 4GB connected to the top PCIe slot.
Why 4K is so low ? other are also lower 20-30% then reviews.
9 REPLIES 9
Esteemed Contributor III
AmitAmit,
Thanks for posting in the forum. As far as we can see on the picture you attached, the sequential speed (read & write) is above according to the specs, you can check this http://ark.intel.com/compare/86739,88744,86740 link.Now, as per the 4k result, we need you to please follow this http://www.intel.com/content/dam/support/us/en/documents/ssdc/hpssd/ssd-750/sb/intel_ssd_750_series_... performance guide, that will explain how the test was run and how to set it up.Please let us know if you require any more information.NC
aamit1
New Contributor
Hi thank you.
In the Document:
3.1
• Do not format the 750 Series SSD
But i did format it using Computer manager -> Disk managment -> Create simple volume wizard.
Without it I can't create a volume from my SSD in windows...
EDIT:
And how i Start this IOmeter.exe? i cant find it in windows search
AmitAmit,
Thanks for the reply.You can go ahead and download the software in the following http://sourceforge.net/projects/iometer/files/iometer-stable/1.1.0/iometer-1.1.0-win64.x86_64-bin.zi... link, once you have the program, please follow all the instructions on how to setup the program.About the SSD format, it is not a problem if you did, you should be able to run the test.Please let us know the outcome.NC
AmitAmit,
We are following up on this thread and we would like to know if you require anymore assistance or if you were able to run the test with the IOmeter*We will be waiting for your response.NC
