cancel
Showing results for
Search instead for
Did you mean:
new fw 8860 for x25-e
Esteemed Contributor III
I bought X-25-E 64GB some days ago. There are FW 8860. But in official site only FW 8850 is.
What is it? New FW without announcement?
10 REPLIES 10
Found this:
http://docs.google.com/viewer?a=v&q=cache:W0Lv9wcmXW4J:content.intel.pcnalert.com/dm/d.aspx/34D8E2AE... http://docs.google.com/viewer?a=v&q=cache:W0Lv9wcmXW4J:content.intel.pcnalert.com/dm/d.aspx/34D8E2AE...
Description of Change to the Customer:
Intel is upgrading the firmware for its High Performance X25-E SLC Solid-State Drives to version 8860. This change provides incremental improvements from the previous version. Inventory will transition in the Intel factory on or beyond the above date.( Jan 04, 2009)
The following changes apply:
MM# 896432
The SA# changes from E41512-906 to E41512-907
MM# 896474
MM# 899386
The SA# changes from E56514-904 to E56514-905
MM# 899387
MM# 904475
The SA# changes from E78714-905 to E78714-906
MM# 904476
The SA# changes from E78719-903 to E78719-904
MM# 904473
The SA# changes from E77779-905 to E77779-906
MM# 904474
The SA# changes from E77775-903 to E77775-904
Please contact your Field Sales Personnel for additional details.
Customer Impact of Change and Recommended Action:
No Customer Impacts are anticipated.
Thanks, redux!
My "old" X25-E has FW 8790 and SA: E41512-904 which isn't listed in the document.
Does that imply that I wont be able to upgrade my ssd IF Intel releases a new FW update?
just checked, my ssd has MM# : 896432 which is listed in the document
Looks like something went wrong again with 8860 firmware. At least I don't see it anywhere except some korean web pages, with no access....
Message was edited by: w00thisButtonDo&# 13; &# 13; http://www.myssd.co.kr/read.html?tkind=7&lkind=39&mkind=509&page=1&num=499875 http://www.myssd.co.kr/read.html?tkind=7&lkind=39&mkind=509&page=1&num=499875&# 13; &# 13; If somebody can download it let me know
I have just bought X25-E (firmware 8860) and got a problem with motherboard Gigabyte P67A-UD5-B3:
X25-E is'not recognized as AHCI drive on SATA600 controller...
X25-M is recognized, but X25-E is not recognized on SATA600 controller.
I cannot even boot from HDD.
By the way, on SATA300 controller there is no problems with both SSDs
I Have found words about improvments on latest(Jan 2011) firmware for X25-M and SATA600 ( http://downloadmirror.intel.com/18363/eng/Release%20Notes.PDF http://downloadmirror.intel.com/18363/eng/Release%20Notes.PDF ) , but there is no fresh firmware for X25-E...
Is it possible to found fresh firmare (may be beta) for X25-E with improvments SATA600?
I don't know why evenlatest firmware 8860 is absent on support.intel.com, there is only 8850 there.
p.s. I have a lot of issues and searches for new firmware in Internet:
http://lists.freebsd.org/pipermail/freebsd-current/2009-November/013629.html http://lists.freebsd.org/pipermail/freebsd-current/2009-November/013629.html
/thread/14755 http://communities.intel.com/thread/14755
http://www.storagereview.com/how_improve_low_ssd_performance_intel_series_5_chipset_environments http://www.storagereview.com/how_improve_low_ssd_performance_intel_series_5_chipset_environments
/message/101696# 101696 http://communities.intel.com/message/101696# 101696
