Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
nvme 3608 error msg: IO queues not created
Community Manager
Hi all,
On my
server (HPE DL380 G9) I have a Problem with my P3608 4TB Card.
After about 3 months in operations, I lose the first controller after a reboot, the second one by the next reboot. And now, I can't access the card with the isdct tool. It seems that the controller is offline.
Short description:
I have created a raid 0 with two cards (one file system whit 7.4 TB capacity).
I use a Debian 8 system with the newest SSD firmware (8DV101F0)
Does anyone have a good idea?
Thx
Roger
Community Manager
Hello Roger_MCH,
First of all, we would like to know if you followed http://www.intel.com/content/dam/support/us/en/documents/ssdc/data-center-ssds/Intel_Linux_NVMe_Guid... these instructions when it was working?
What kind of workload do you put on the SSD?
We will be waiting for your response, in case you need further assistance let us know here, or contact our http://www.intel.de/content/www/de/de/support/contact-support.html# @18 support department.
NC
Community Manager
Hello NC,
Many thanks for your Feedback. We use "Proxmox" as a virtualization solution. This solution is using the Ubuntu 16.04 LTS 4.4 kernel. The driver is activated by default.
In the current system, I have combine two P3608 4TB cards to a Raid 0 volume (# zpool create -f -o ashift = 12 ssd_pool /dev/nvme0n1 /dev/nvme1n1 /dev/nvme2n1 /dev/nvme3n1)
On the server runs a weather application which imports and writes many data. The data can be weather models (large files) or small files like point data.
It is already the second card which has logged off respectively has deactivated. I have opened a support case by Intel; the result was a 1:1 Replacement without any additional information.
Roger
Community Manager
Hello Roger_MCH,
Without performing more troubleshooting and getting more data, it may be hard to positively diagnose the cause of your drive failures.
However, it might be worth noting that each P3608 counts as two drives. So if you RAID 0 two pairs of these SSDs, it would be the same as creating a RAID 0 array with four SSDs. Which does increase the expected failure rate by about 80%. Perhaps a RAID 10 would be a better option?
The endurance rating of the Intel® SSD DC P3608 allows for 3 drive writes per day, or 21.90 Petabytes Written. Exceeding this would be another possible cause for the drive to fail earlier than expected.
In many cases if an SSD fails in a raid, we recommend removing the drive from the array and performing a secure erase/low level format. More often than not, this allows the drive to recover successfully. Although this may have been out of the question if your drives were no longer detected at BIOS level.
Carlos A.
Community Manager
Hi Carlos
I also think that a Raid 10 would be better but the cost is also much higher. We write about 500GB ~ 700GB data per day to the disc. This should be not a problem.
Question, how I can do a secure erase/low Level format from the ssd-card respectively from the effected controller?
Error message for the /var/log/messages
Dec 14 17:58:51 zuenjv05 kernel: [ 9.822799] nvme 0000:87:00.0: Failed status: 0x3, reset controller.
Dec 14 17:58:51 zuenjv05 kernel: [ 9.823291] nvme 0000:87:00.0: Cancelling I/O 0 QID 4
Dec 14 17:58:51 zuenjv05 kernel: [ 9.823294] nvme 0000:87:00.0: Cancelling I/O 1 QID 4
Dec 14 17:58:51 zuenjv05 kernel: [ 9.823296] nvme 0000:87:00.0: Cancelling I/O 2 QID 4
Dec 14 17:58:51 zuenjv05 kernel: [ 9.823298] nvme 0000:87:00.0: Cancelling I/O 0 QID 1
Dec 14 17:58:51 zuenjv05 kernel: [ 11.383135] nvme 0000:87:00.0: IO queues not created
Some additional details:
mailto:root@zuenjv05:/sys root@zuenjv05:/sys# lspci -nn | grep -i ssd
0d:00.0 Non-Volatile memory controller [0108]: Intel Corporation PCIe Data Center SSD [8086:0953] (rev 02)
0e:00.0 Non-Volatile memory controller [0108]: Intel Corporation PCIe Data Center SSD [8086:0953] (rev 02)
86:00.0 Non-Volatile memory controller [0108]: Intel Corporation PCIe Data Center SSD [8086:0953] (rev 02)
87:00.0 Non-Volatile memory controller [0108]: Intel Corporation PCIe Data Center SSD [8086:0953] (rev 02)
root@zuenjv05:/sys#
find . -name "*nvme*"
./bus/pci/drivers/nvme
./devices/pci0000:00/0000:00:03.2/0000:0b:00.0/0000:0c:01.0/0000:0d:00.0/nvme
./devices/pci0000:00/0000:00:03.2/0000:0b:00.0/0000:0c:01.0/0000:0d:00.0/nvme/nvme0
./devices/pci0000:00/0000:00:03.2/0000:0b:00.0/0000:0c:01.0/0000:0d:00.0/nvme/nvme0/nvme0n1
./devices/pci0000:00/0000:00:03.2/0000:0b:00.0/0000:0c:02.0/0000:0e:00.0/nvme
./devices/pci0000:00/0000:00:03.2/0000:0b:00.0/0000:0c:02.0/0000:0e:00.0/nvme/nvme1
./devices/pci0000:00/0000:00:03.2/0000:0b:00.0/0000:0c:02.0/0000:0e:00.0/nvme/nvme1/nvme1n1
./devices/pci0000:80/0000:80:02.0/0000:84:00.0/0000:85:01.0/0000:86:00.0/nvme
./devices/pci0000:80/0000:80:02.0/0000:84:00.0/0000:85:01.0/0000:86:00.0/nvme/nvme2
./devices/pci0000:80/0000:80:02.0/0000:84:00.0/0000:85:02.0/0000:87:00.0/nvme
./devices/pci0000:80/0000:80:02.0/0000:84:00.0/0000:85:02.0/0000:87:00.0/nvme/nvme3
./block/nvme0n1
./block/nvme1n1
./class/nvme
./class/nvme/nvme0
./class/nvme/nvme1
./class/nvme/nvme2
./class/nvme/nvme3
./class/block/nvme0n1
./class/block/nvme1n1
./module/nvme
./module/nvme/drivers/pci:nvme
2234 Handle 0x00EC, DMI type 203, 34 bytes
2235 OEM-specific Type
2236
Header and Data:
2237 CB 22 EC 00 FE FF FE FF 86 80
53 09 86 80 09 37
2238 01 08 EB 00 00 00 10 0A 02 01
FF FF 01 02 03 04
2239 00 00
2240
Strings:
2241
PciRoot(0x0)/Pci(0x3,0x2)/Pci(0x0,0x0)/Pci(0x1,0x0)/Pci(0x0,0x0)
2242 NVMe.Slot.2.1
2243 NVM Express Controller
2244 Slot 2
2245
2246 Handle 0x00ED, DMI type 203, 34 bytes
2247 OEM-specific Type
2248
Header and Data:
2249 CB 22 ED 00 FE FF FE FF 86 80 53 09 86 80 09
37
2250 01 08 EB 00 00 00 10 0A 02 02
FF FF 01 02 03 04
2251 00 00
2252
Strings:
2253
PciRoot(0x0)/Pci(0x3,0x2)/Pci(0x0,0x0)/Pci(0x2,0x0)/Pci(0x0,0x0)
2254 NVMe.Slot.2.2
2255 NVM Express Controller
2256 Slot 2
2282 Handle
0x00F0, DMI type 203, 34 bytes
2283 OEM-specific Type
2284
Header and Data:
2285
CB 22 F0 00 FE FF FE FF 86
80 53 09 86 80 09 37
2286 01 08 EF 00 00 00 09 0A 05 02
FF FF 01 02 03 04
2287 00 00
2288
Strings:
2289
PciRoot(0x1)/Pci(0x2,0x0)/Pci(0x0,0x0)/Pci(0x1,0x0)/Pci(0x0,0x0)
2290 PCI.Slot.5.2
2291 NVM Express Controller
2292 Slot 5
2293
2294 Handle 0x00F1, DMI type 203, 34 bytes
2295 OEM-specific Type
2296
Header and Data:
2297
CB 22 F1 00 FE FF FE
FF 86 80 53 09 86 80 09 37
2298 01 08 EF 00 00 00 09 0A 05 03
FF FF 01 02 03 04
2299 00 00
2300
Strings:
2301
PciRoot(0x1)/Pci(0x2,0x0)/Pci(0x0,0x0)/Pci(0x2,0x0)/Pci(0x0,0x0)
2302 PCI.Slot.5.3
2303 NVM Express Controller
2304 Slot 5
2305
root@zuenjv05:/dev#
dmidecode --type 9
# dmidecode
2.12
SMBIOS 2.8
present.
Handle
0x00BC, DMI type 9, 17 bytes
System Slot
X...
Community Manager
Hello Roger_MCH,
The same tool we always recommend for monitoring data center drives can also be used to perform a secure erase:
- https://downloadcenter.intel.com/download/26221/Intel-SSD-Data-Center-Tool Intel® SSD Data Center Tool (available for Windows*, VMware*, and Linux*).
- http://www.intel.com/content/www/us/en/support/solid-state-drives/000020016.html User and Installation Guides for ISCT.
If you haven't already completed the RMA process for your drives, you may try this out and let us know if this helps.
Carlos A.
Community Manager
Hi Carlos A.
I know the document.
I had installed the card in a Windows Workstation, including the Data Center Tool software. The result was the same.
Status: Selected drive is in a disable Logical state.
What is the possibility to enable the card?
It seems that I'm not alone with this problem.
Merry christmas to you all.
Roger
Community Manager
Hello Roger_MCH,
You may try re-seating the drive, and then running the delete command again. But since the drives are part of a raid array, it would be best to try doing this in a different system.
However, if it all fails, then the next step would be to proceed with the RMA.
We hope you have a wonderful Christmas weekend as well.
Best regards
Carlos A.
Community Manager
Hello Carlos A.
I removed the card from the source system and installed it in a Windows computer. Unfortunately without any success.
Many thanks for your support.
Greetings and a happy new year.
Roger
Community Manager
Hi Roger_MCH,
We understand you removed the SSD and installed it again in a different system (Windows*); but, it is still not working, correct?
Can you please let us know what is the status of the LED lights on your SSD?
Also, could you please run Intel® SSD Data Center Tool and type: isdct.exe show -a
We will be waiting for your response.
NC
Community Manager
Hi all,
I wish you a good start into the new year!
The card was installed in an HP DL380 G9 server.
I have had removed the (disabled) card from the server and I had installed it in a Windows workstation.
The LED status
The command output
C:\isdct>isdct.exe show -a -intelssd 0
- Intel SSD DC P3608 Series CVF85486002X4P0DGN-1 -
AggregationThreshold : Selected drive is in a disable logical state.
AggregationTime : Selected drive is in a disable logical state.
ArbitrationBurst : Selected drive is in a disable logical state.
Bootloader : 8B1B0133
CoalescingDisable : Selected drive is in a disable logical state.
ControllerCompatibleIDs : PCI\\VEN_8086&DEV_0953&REV_02PCI\\VEN_8086&DEV_0953PCI\\VEN_8086&CC_010802PCI\\VEN_8086&CC_0108PCI\\VEN...
ControllerDescription : @oem168.inf,%pci\\ven_8086&dev_0953.devicedesc%;Intel(R) Solid-State Drive P3700/P3600/P3500/750 Series
ControllerID : PCI\\VEN_8086&DEV_0953&SUBSYS_37098086&REV_02\\6&37F79443&0&00080008
ControllerIDEMode : False
ControllerManufacturer : @oem168.inf,%intel%;Intel
ControllerService : IaNVMe
DevicePath : \\\\.\\SCSI1:
DeviceStatus : *ASSERT_405C786C AA
DriverDescription : Intel(R) Solid-State Drive P3700/P3600/P3500/750 Series
DriverMajorVersion : 1
DriverManufacturer : Intel
DriverMinorVersion : 7
ErrorString : *ASSERT_405C786C AA
Firmware : 8DV101F0
FirmwareUpdateAvailable : Please contact Intel Customer Support for further assistance at the following website: http://www.intel.com/go/ssdsupport http://www.intel.com/go/ssdsupport.
HighPriorityWeightArbitration : Selected drive is in a disable logical state.
IOCompletionQueuesRequested : Selected drive is in a disable logical state.
IOSubmissionQueuesRequested : Selected drive is in a disable logical state.
Index : 0
Intel : True
IntelGen3SATA : False
IntelNVMe : True
InterruptVector : Selected drive is in a disable logical state.
LatencyTrackingEnabled : Selected drive is in a disable logical state.
LowPriorityWeightArbitration : Selected drive is in a disable logical state.
MediumPriorityWeightArbitration : Selected drive is in a disable logical state.
ModelNumber : INTEL SSDPECME040T4
NVMeControllerID : 0
NVMeMajorVersion : 1
NVMeMinorVersion : 0
NVMePowerState : Selected drive is in a disable logical state.
NVMeTertiaryVersion : 0
NamespaceId : 4294967295
NativeMaxLBA : Selected drive is in a disable logical state.
NumErrorLogPageEntries : 63
OEM : Generic
PCILinkGenSpeed : 3
PCILinkWidth : 4
PNPString : PCI\\VEN_8086&DEV_0953&SUBSYS_37098086&REV_02\\6&37F79443&0&00080008
PowerGovernorMode : Selected drive is in a disable logical state.
Product : Fultondale X8
ProductFamily : Intel SSD DC P3608 Series
ProductProtocol : NVME
SCSIPortNumber : 1
SMARTEnabled : True
SMARTHealthCriticalWarningsConfiguration : Selected drive is in a disable logical state.
SMBusAddress : Selected drive is in a disable logical state.
SectorSize : 512
SerialNumber : CVF85486002X4P0DGN-1
TCGSupported : False
TempThreshold : Selected drive is in a disable logical state.
TimeLimitedErrorRecovery : Selected drive is in a disable logical state.
TrimSupported : True
VolatileWriteCacheEnabled : Selected drive is in a disable logical state.
WriteAtomicityDisableNormal : Selected drive is in a disable logical state.
C:\isdct>isdct.exe show -a -intelssd 1
- Intel SSD DC P3608 Series CVF85486002X4P0DGN-2 -
ControllerID : PCI\\VEN_8086&DEV_0953&SUBSYS_37098086&REV_02\\6&146834E4&0&00100008
ControllerS...
Community Manager
Hello Roger_MCH,
Happy new year as well!
From what we can see, the drive keeps showing as disabled logical state, but the light is solid green.
We need to ask you first, do you have another P3608 card? The one tested in Linux?
This because that one shows just fine, as it should, when you ran the command and checking the ISNs of each card, we do see those are different. If this is the case, we suggest you to get in touch with our http://www.intel.eu/content/www/eu/en/support/contact-support.html# @18 support department to get further assistance.
Please let us know once you get in contact with them.
NC
Community Manager
Hi NC,
What do you mean with checking the ISNs (Intel Software Network)?
Yes, we had bought a lot of these cards.
And yes, I had opened two Intel support tickets (01911082 and 02193992) from a long time. But the answer respectively the analyze/resolving from the problem is/was not very helpful.
Thanks again for your support.
Roger
Community Manager
Hi Roger_MCH,
First of all, the ISN is the number we use on each SSD as an identifier and it is unique. (Kind of like a serial number).
We will verify the case numbers you provided and we will get back to you with a response.
NC
Community Manager
Hello Roger_MCH,
Let us inform you that both cases are escalated and our engineering team is working on this. We will get back to you soon, either from this thread or by e-mail.
NC
Community Manager
Roger_MCH,
We would like to verify something else with you before continuing with the resolution for this case:
-Can you confirm if the cards are connected directly to the server and not to a RAID controller card?
-Did you install our NVMe* driver?
-Did you try the cards with a supported OS and tested Intel® Data Center Tool?
This in order to discard any other card functionality. We will be waiting for your response.
NC
Community Manager
Hi Roger_MCH,
We are following up and we would like to know if you can reply back to the questions we sent on previous post.
In case you don't need further assistance, please let us know as well.
NC
Community Manager
Hi NC,
- The cards are installed into the PCIe 8x Slots (whiteout any other devices). I had built the volume with ZFS over all p3608 controllers.
- Proxmox use the NVMe Driver from Ubuntu 16.04.
- Yes see my answer in the community from 23.12.2016 to Carlos (Windows 7).
Notes
I use the following Linux-Support packages Intel® SSD Data Center Tool DataCenterTool_3_0_2_Linux.zip (Version: 3.0.2) for the reporting.
Question
For Windows exist a new Version of Intel® SSD Data Center Family for NVMe Drivers (Version: 1.8.0.1011) but not for Linux. Do you have the possibility to provide the newest version?
Roger
Community Manager
Hi Roger_MCH,
Thanks for the details provided.
We will be addressing your question with our team, we will keep you posted.
NC
Community Manager
Hi Roger_MCH,
We understand our support department got in touch with you already, please in case of any other question or help needed, do not hesitate to contact us back again.
Have a nice weekend.
NC
JRadl
What was the outcome - i have a very similar situation -
I have 4 "Intel Corporation PCIe Data Center SSD [8086:0953] (rev 01)" cards in my server - suddenly 3 of them aren't accessible any more
from kernel.log:
May 18 14:30:56 bhsviosl kernel: nvme0n1: p1 p2
May 18 14:30:56 bhsviosl kernel: nvme 020d:01:00.0: Could not set queue count (6)
May 18 14:30:56 bhsviosl kernel: nvme nvme1: IO queues not created
May 18 14:30:56 bhsviosl kernel: nvme 020e:01:00.0: Could not set queue count (6)
May 18 14:30:56 bhsviosl kernel: nvme nvme2: IO queues not created
May 18 14:30:56 bhsviosl kernel: nvme 020f:01:00.0: Could not set queue count (6)
May 18 14:30:56 bhsviosl kernel: nvme nvme3: IO queues not created
Firmware level for all 4 is 8EV101F0
