Community
cancel
Showing results for
Search instead for
Did you mean:
LFink2
overheating on acer aspire7 with i7-8750h processor when Windows on Intel 660p installed
Hello, I recently installed on my laptop Intel 660p NVMe SSD 512GB. My laptop is Acer aspire 7 A715-72g and default configuration had HDD. I installed intel SSD and installed WIndows here. But after installing my processor overheats (with minimal usage it has around 50-60s Celsius and with minimal work it suddenly goes over 70-85s Celsius, which didnt happen when windows were installed on HDD - I cleaned notebook so no ash is inside, so problem is probably in some setting or something. In bios I have option RST with intel optane). Thanks for support
AdrianM_Intel
Hello LFink2
I understand you are concern about the temperatures of your processor, even though the temperatures are around 50-60s Celsius and when it's working go over 70-85s Celsius it's still working withing specifications, however, the issue started after the change was done on your laptop specifically when the new SSD was integrated, so the SSD works faster than an HDD which might produce more heat in the system, also the manufactures can customize their hardware to work with specific components to keep the system working within specifications, my recommendation is to check with the system manufacturer to validate any new hardware integration on your system since you might need any new hardware component example: (Cooler), especially on laptops due to the case form factor can be design for certain components.
Adrian M.
A Contingent Worker at Intel
LFink2
Thank you for answer, I will ask manufacturer for more information.
