Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
parition alignment of X25-M G2 under Linux
How should one partition an X25-M G2 under Linux? I have read two different suggestions, both of which suggest using fdisk with a custom head and sector count, but they differ on the actual values. Both agree that partitions need to be aligned based on the SSD's erase block size. I believe that the X25-M for example uses an EBS of 512 KiB.
1) fdisk -H 224 -S 56 /dev/sdX
2) fdisk -H 32 -S 32 /dev/sdX
References: http://ldn.linuxfoundation.org/blog-entry/aligning-filesystems-ssd%E2%80%99s-erase-block-size 1 and http://www.nuclex.org/blog/personal/80-aligning-an-ssd-on-linux 2
Advice is appreciated.
MBall5
New Contributor II
Hello, unfortunately we do not support Linux; I suggest looking for this info under the Linux forums of support.
