cancel
Showing results for
Search instead for
Did you mean:
problem intel SSD 530 AHCI
smore101
New Contributor
First, sorry for my english ( i m french )
I buy intel SSD 530 to install windows 7 64 bits.My motherboard is MSI GAMING Z87GD65 with intel 4770K processor.
I have big problem to install windows because windows installer say me controller not good in BIOS.
After lot of hours , i find good parameter of AHCI to install windows on it ( all IDE Mode )
The problem is i can't switch to AHCI mode, my SSD is on Z87 Sata port. Before SSD 530 , i have X-25M SSD and AHCI was OK.
Then i test the performance to SSD and i don't have good one. I have other SSD and HDD ( it s the same if i let only SSD 530 only ) then all the other DD cannot have AHCI because intel 530 cannot like it. When i put AHCI ( only with 530 ) windows cannot load and the screen was blocked
My motherboad, drivers, ssd firmware is update at last version. I have check on internet , i'm not the only guy with this problem.
How we do , please to have full AHCI function?
Thanks for your help
Tiff
11 REPLIES 11
joe_intel a écrit:
You may contact http://www.intel.com/p/en_US/support/contactsupport Intel support but I wanted to ask some questions first:
Do you get the same result after optimizing the drive with https://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=18455 Intel® SSD Toolbox?
Do you have another system you can use to test the Intel® SSD?
Yes , after SSD toolbox optimizing the drive same result see picture:
To compare the Samsung test plug in the same shipset Z87
Then ???
Jose_H_Intel1
Valued Contributor II
Please contact your nearest http://www.intel.com/p/en_US/support/contactsupport Intel support team.
