Intel® Optane™ Solid State Drives
Support for Issues Related to Solid State Drives based on Intel® Optane™ technology, Intel® MAS and Firmware Update Tool
435 Discussions
que ventajas tien los ssd con relacion a Kington por ejemplo?
quisiera entender cuales son las ventajas de ssd de Intel frente a las marcas mas vendidas en Colombia con Kingston
YANNLY,
Intel aims total customer satisfaction when it comes to Intel® SSDs. Currently we have four families of SSDs. They are listed below. In each link, you are going to find a comparison among each specification and density. Its usage will depend on the intention of the customer. Not all motherboards are compatible depending on the series. You may want to consult full specifications of each drive already included in the links in order to see which one will be the best for your system and intentions.
As for other brands such as Kingston*, you want to contact them directly for additional support on this matter.
Consumer SSDs
http://ark.intel.com/compare/86741,86739,88743,88744,86742,86740 Intel® SSD 750 Series
http://ark.intel.com/compare/81039,81038 Intel® SSD 730 Series
http://ark.intel.com/compare/94204,94421,94209,94434,94207,94331,94203,94328,94213,94334,94420,94332 Intel® SSD 540 Series
http://ark.intel.com/compare/86729,86722,86737,86728,86734,86725,86731,86727,86738,89330 Intel® SSD 535 Series
http://ark.intel.com/compare/75336,77950,75334,75333,75331,75328,75338,77949,75613,75611,75337,77948,75614 Intel® SSD 530 Series
http://ark.intel.com/compare/71181,71180,71179,74497,71183 Intel® SSD 525 Series
http://ark.intel.com/compare/?ids=56583,56584,56585,66247,66248,66249,66250,66251,56576,56577,71527,67286,67287,67288,70274,56568,56571,56563,56564,56565,56566,56567,56569,66289,66288,66291,66290,56551,56552,56546,56547,56607,56601,56604,56599,56600,56603,56595,56596,56589,56592,56588,56591 Legacy Consumer SSDs
Professional SSDs
http://ark.intel.com/compare/94452,94453,94445,94455,94447,94451,94446,94450,94449,94448,94444,94443 Intel® SSD Pro 5400s Series
http://ark.intel.com/compare/81049,86736,81048,86721,81047,86733,91956,81046,86723,81045,86735,81044,86724,81043,86732,91955,81041,86730 Intel® SSD Pro 2500 Series
http://ark.intel.com/compare/78064,78065,78066,78068,78069,78071,78072,78074,78075,78076 Intel® SSD Pro 1500 Series
Data Center SSDs
http://ark.intel.com/compare/82937,84239,84238,82939 Intel® SSD DC S3710 Series
http://ark.intel.com/compare/71915,71918,71914,71917,71913 Intel® SSD DC S3700 Series
http://ark.intel.com/compare/82934,82933,82936,82935,86641,86640,92225 Intel® SSD DC S3610 Series
http://ark.intel.com/compare/86192,86191,86199,86197,86195,86193,86200 Intel® SSD DC S3510 Series
http://ark.intel.com/compare/74938,82118,75685,75686,74944,75684,75683,84290,75682,75680,75681,75679,82113,75678,74949,82114,75676 Intel® SSD DC S3500 Series
http://ark.intel.com/compare/94577,94578,94579,94580 Intel® SSD DC S3100 Series
http://ark.intel.com/compare/79621,79620,79619,79618,79627,79626,79625,79624 Intel® SSD DC P3700 Series
http://ark.intel.com/compare/88735,88734,88731 Intel® SSD DC P3608 Series
http://ark.intel.com/compare/80995,80994,80993,80992,80991,80990,80999,80998,80997,80996 Intel® SSD DC P3600 Series
http://ark.intel.com/compare/79633,79632,82851,82850,82847,82846 Intel® SSD DC P3500 Series
http://ark.intel.com/compare/67009,67008 Legacy Data Center SSDs
Embedded SSDs
http://ark.intel.com/compare/94603,94604 Intel® SSD E 5410s Serie
http://ark.intel.com/compare/94442,94437,94440,94441,94436,94439,94438 Intel® SSD E 5400s Series
Please, let us know if there is anything else we can help you with.
Aleki
YANNLY,
We haven't heard from you in a while so we would like to know if you have any more questions about the Intel® SSDs.
Aleki
