Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
"Accelerate" Button Problem for SSD drive under RST
I have met the following requirements:
Updated my Asus P8Z68-V Pro to Bios 501
Using the latest 10.5.0.1027 the Bios RST is 10.5.0.1034
my operating system is Windows 7 32bit and is on the RAID 1 set of Hitachi drives 2 drives of 2 Terabyes each
My SSD is the OCZ 60 GB Agility 3
All drives are on the intel SATA Ports and the Bios is set to RAID
My HD are OEM Hitachi Deskstar 5K3000 are on the SATA 3g ports and the SSD on the 6g port
When I boot with these drives only there is no Accelerate Button
When I add my Samsung 250 gig drive the Accelerat Button appears.....
I know the SSD will write up to 475 MS/s and read up to 525 MB/s
Why can't I get the Accelerate button for my fast drives?
Community Manager
What provides this "Accelerate" button you mentioned? What software or function displays or provides that button, and what does it do?
Community Manager
The RST is Intel's Rapid Storage Technology driver which allows the SSD drive to act as a Cache for the whole hard drive up to 65 GB to improve Drive perfermance by 40%. It puts the most used parts of programs and data on the SSD drive. The accelerate button appears when you have the right Intel chip set on the motherboard (Z68) with the requirements I listed.
Community Manager
Ok, I see, thanks, that's how they're doing the SSD caching thing. From what I can see, you have met the requirements, although it seems like your OS on your RAID set of Hitachi drives is being excluded as part of the caching function, yet your other drive (without an OS?) is. You might want to check the following and similar threads for some answers. Sorry I am not familiar with this feature:
/message/126681# 126681 http://communities.intel.com/message/126681# 126681
Community Manager
I now have it working as stated it should work....
here was the problem....
I had 2 2TB drives set as raid. It seemed it was always verifying the drives. As soon as I hit the cancel button the Accelerate button worked...
Why....I have no idea....but it does work now....at least for one boot.....
I also updated to Intel RST 10.5.1.1001
Where you find it.....I have no idea....my Driver Genius Professional found it somewhere and it works....I could not find it anywhere else.....
Hope this helps!!
Community Manager
That's great, I hope it works well for you. I need to study it a bit, I don't understand where the OS resides in this type of configuration. I perform manual SSD caching myself now, important things on the SSD, others on HDD. I can appreciate this feature as a "set and forget" type of thing.
A Z68 RST driver ought to be available from the Download page for your mother board.
This is the RST driver for the only (as of 6/20/11) Intel Z68 desktop mother board, the DZ68DB, the only way I could find to get it for the Z68 chipset directly from Intel:
http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20023&ProdId=3334&lang=eng&OSVersion=... http://downloadcenter.intel.com/Detail_Desc.aspx?agr=Y&DwnldID=20023&ProdId=3334&lang=eng&OSVersion=...
This may not be a generic Z68 RST driver, as the page mentions the need to use a certain BIOS/EFI version with it. If your driver works fine for you now, I'd say stick with it, or try this one at your own risk...
Community Manager
Actually I installed the operating system on the RAID 1 HDD and use the full 60 GB of the SSD as Cache. The driver I used is a newer version of the link that you posted.
