Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
"Access violation" exception in SSD Toolbox 3.1.2 running with -drive_serial parameter or using scheduled SSD Optimizer (Trim)
Jump to solution
Hi.
Found bug: "Access violation" exception in SSD Toolbox 3.2.1 running with -drive_serial parameter if the RAID volume name has spaces, for example "Stripe 1". Execution of the scheduled SSD Optimizer (Trim for RAID volume) would fail because of using this parameter in the job settings of Windows Task Scheduler. Of course this can be easily avoid by manually editing the job settings without using -drive_serial parameter and use -drive_letter or -drive_index parameters instead.
Configuration:
Hardware:
MB: Asus P5Q-E (BIOS version: 2101)
Storage controller: Intel ICH10R in RAID mode (IRST driver version: 11.7.0.1013)
Storage controller: Marvell 88SE6121 + Silicon Image Sil5723 port multiplier in JBOD mode (Marvell RAID driver version: 1.2.0.8400)
SSDs: 2 x Intel SSDSA2BW160G3 on ICH10R in RAID0 mode
HDDs: Seagate ST3320418AS, Seagate ST31000528AS, Seagate ST32000645NS, Seagate ST32000645NS on ICH10R in Non-RAID mode HDDs: Seagate ST32000645NS on Marvell 88SE6121 + Silicon Image Sil5723 port multiplier in JBOD mode
HDDs: Seagate ST31000528AS on Marvell 88SE6121 eSATA inside Sarotech HardBox 3.0 Combo W-31US3 Plus (hot plugged/unplugged periodically)
Software:
OS: MS Windows 7 Ultimate x64 SP1 Russian
.NET Framework installed in GAC: 2.0 SP 2, 3.0 SP 2, 3.5 SP 1, 4.0 (Client & Full)
IRST: 11.7.0.1013
SSD Toolbox: 3.1.2
Marvell MSU: 1.2.0.1032
Silicon Image 57xx SteelVine: 5.1.24B
Tags (2)
Jose_H_Intel1
Hello Mosc. Thank you for posting.
The Intel® SSD Toolbox will only provide TRIM support for RAID 0 on 7 series motherboards (when using Intel® chipset). In this case the results you are getting regarding TRIM support might be purely cosmetic since the combination of SATA controller and RAID is not supported. For your system TRIM is supported if using Intel® ICH10R with a single AHCI (non RAID) drive. This is due to a limitation of the SATA controller unable to translate the TRIM command from SATA to SCSI.
Jose_H_Intel1
Community Manager
Hi, Joe.
According to info I found (for ex. in Intel SSD Toolbox Help) TRIM is supported on ICH10R in RAID0 and that is my case (see hardware configuration in my previous post: 2 x Intel SSDSA2BW160G3 on ICH10R in RAID0 mode).
Quote from Intel SSD Toolbox Help:
Intel® SSD Optimizer Requirements
† The Intel SSD Optimizer can be used on a drive in a RAID array if all of the following conditions are true:
  • The drives are configured as RAID0
  • Version 11.0 or later of Intel® Rapid Storage Technology (RST) is installed
  • All drives in the RAID array are Intel SSDs that support Trim
  • The array is healthy
  • The operating system is not Windows 8 or Windows Server 2012
Jose_H_Intel1
Please accept our apologies for this inconvenience since the information from the SSD Toolbox Help is incorrect. We will address this issue in a future release.
Thanks for your comprehension.
