cancel
Showing results for
Search instead for
Did you mean:
"Device is not Ready" Disc management said
vagba
New Contributor
i cant initialize my ssd
each and everytime it says the device is not ready.
unknown but have the capacity on it
5 REPLIES 5
jbenavides
Valued Contributor II
Hello Vonbryan,
- Try using a different SATA port and cable, and check if the issue is resolved.
- If the situation persists, please attempt doing a Secure erase on the SSD.
If SSD toolbox is not be able to do this In Windows 7 or 8 due to a Security Freeze Lock, you may try one of the 3rd party tools mentioned in the following advisory:
* We advise you to check the information and documentation for each tool before downloading, and choose the one that best suits your needs.
http://www.intel.com/support/ssdc/hpssd/sb/CS-032319.htm When to Run a Low-Level Format on an Intel® Solid-State Drive?
