Community
cancel
Showing results for
Search instead for
Did you mean:
vagba
"Device is not Ready" Disc management said
i cant initialize my ssd
each and everytime it says the device is not ready.
unknown but have the capacity on it
Jose_H_Intel1
Hi Vonbryan, may I ask for the brand and model of your SSD, the computer model and operating system being used?
How is the drive connected to your system?
Did you try a secure erase on the drive?
vagba
series s3500 DC 800gb
windows 7 64/bit
main board sata 3
using ga970a ds3p
the toolbox detect the ssd but every option there like secure erase doesnt work or that button is disable
and if i scan there toolbox always get Error: An error was detected reading data from the selected Intel SSD. Contact your reseller or local Intel representative for assistance.
Jose_H_Intel1
Do you have the option to test the drive in a different system to see if the issue follows the drive?
vagba
yes mr joe i still got the same problem
jbenavides
Hello Vonbryan,
- Try using a different SATA port and cable, and check if the issue is resolved.
- If the situation persists, please attempt doing a Secure erase on the SSD.
If SSD toolbox is not be able to do this In Windows 7 or 8 due to a Security Freeze Lock, you may try one of the 3rd party tools mentioned in the following advisory:
* We advise you to check the information and documentation for each tool before downloading, and choose the one that best suits your needs.
http://www.intel.com/support/ssdc/hpssd/sb/CS-032319.htm When to Run a Low-Level Format on an Intel® Solid-State Drive?
