Community
cancel
Showing results for
Search instead for
Did you mean:
CHobb3
"Failed to move the selected data..." Intel Data Migration Software
Jump to solution
So I just bought a new Intel 520 480 GB SSD:
Installed it in the CD bay of my brand new Lenovo W530 running Windows 8.
Installed the latest version of the Data Migration Software
Try to run it using the "Automatic" option and I get:
"Failed to move the selected data. Make sure that your new hard drive is not smaller than your old one and your partitions do not contain errors. You can check for the errors and correct them using a special utility."
So I tried running the manual option. It sees both the existing 120 GB SDD and the new Intel one BUT the existing SSD shows as "Disk 1 - GPT" and is greyed out.
How the hell do I get the migration software to run?
I've tried creating the boot able CD but the latop won't boot from it (trashed two DVDs doing this).
For something what claims to be so simple I'm ready to box everything up and send it back. So much for doing this over the long weekend to minimise the impact to my business where I'm self-employed.
Any help or pointers appreciated as I've burnt hours on this stupid damn thing.
Many thanks in advance,
Cliff
Tags (1)
UHans
New Contributor II
Unfortunately, the software does not support GPT. From page 16 in the manual http://downloadmirror.intel.com/19324/eng/Intel%C2%AE%20Data%20Migration%20Software%20Help.pdf http://downloadmirror.intel.com/19324/eng/Intel%C2%AE%20Data%20Migration%20Software%20Help.pdf : "The current Intel Data Migration Software version does not support cloning of dynamic and GPT disks".
A workaround could be to do a full system image backup on some USB storage using the built-in Windows Backup application and restore it onto the new drive:
http://www.petri.co.il/working-with-system-image-backups-in-windows-7.htm Backup
http://www.petri.co.il/restore-windows-7-from-backup-image.htm Restore
Message was edited by: Oken (fixed a typo and some layout issues)
UHans
New Contributor II
UHans
New Contributor II
A new version of the Intel Data Migration Software has now been released (thanks to Parsec for the heads up). The new version supports GPT and can be downloaded here: http://www.intel.com/support/go/ssdinstallation/ Intel(R) Redirect
