Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
"Unrecognized Fixup Data!" on attempted firmware upgrade
I attempted to upgrade my flash in a qosmio x305 machine today, and got the above error when it/i tried to run issdfut. It appeared to be a FREEDOS error from my google seraching, so i burned a 2nd disk, but the end result was the same. Has anyone else run into this problem?
For the record, the laptop appears to use an intel chipset.
Community Manager
For the record, i got around this issue by doing a USB based update via the instructions at http://communities.intel.com/thread/8906?tstart=0
