Community
cancel
Showing results for
Search instead for
Did you mean:
VTer
raid1 from 2 Intel® SSD DC S3710
how to create raid1 from 2 Intel® SSD DC S3710?
Community Manager
Valerii,
The Intel® SSD DC S3710 can be used in RAID as long as the RAID controller supports these drives.
To configure your RAID array you can use the management interface of your storage adapter. For example: If you are using the storage controller of an Intel Chipset you should be able to access it from the BIOS or in Windows* using the management interface of iRST®.
For additional information, please let us know your motherboard's model and storage adapter you are using.
