Community
cancel
Showing results for
Search instead for
Did you mean:
Community Manager
s.m.a.r.t.
Hi guys
should smart be enabled in bios or not? t.i.a.
tom
Community Manager
Disabled. You need an application in the OS to continously monitor SMART values to be of any use.
http://www.techarp.com/showFreeBOG.aspx?lang=0&bogno=95 http://www.techarp.com/showFreeBOG.aspx?lang=0&bogno=95
If you want, you can use the Intel Solid State Drive Toolbox to read your SMART values from your drive.
Also, note that SMART helps to warn impending drive failure around 64% of the time: labs.google.com/papers/disk_failures.pdf
Community Manager
thank you duckie, great link and even a better read
