Community
cancel
Showing results for
Search instead for
Did you mean:
MKey
secure erase frozen ssd - 180GB 520
I want to erase the data on my SSD as best I can.
The secure erase function in the toolbox just keeps telling me I need to unplug/plug the drive to unlock it - but this doesn't work.
It's a second hand drive, if there are any special codes I need, I haven't got them.
What to do folks ?
Kevin_M_Intel
Hi GreatApe,
Let me help you with this.
Please note that Windows can block the secure erase functionality on some systems. I recommend you creating a Linux Live CD or USB stick and follow the directions here:
http://www.thomas-krenn.com/en/wiki/SSD_Secure_Erase http://www.thomas-krenn.com/en/wiki/SSD_Secure_Erase
NOTE: These links are being offered for your convenience and should not be viewed as an endorsement by Intel of the content, products, or services offered there.
Kevin M
MKey
Thanks I tried it and it worked perfectly. I didn't need to use a live CD I just used my regular ubuntu install and it worked no problem.
Ape
