Community
cancel
Showing results for
Search instead for
Did you mean:
jjuua
sequential write speed 540s
Hi, I wonder if it is normal a rate of about 120 mb sequential write in my ssd 120GB 540s. Thanks
Community Manager
Pipet,
According to your post, the SSD is getting around 120 MB/s sequential write, we would like to ask you, what application are you using to test the SSD?
Here are the http://ark.intel.com/products/94420/Intel-SSD-540s-Series-120GB-2_5in-SATA-6Gbs-16nm-TLC specs of the drive, where you can check the estimated sequential read & write. For testing, we used the IOmeter* software.
If you have any more questions, please let us know.
NC
jjuua
Thanks for answering. The software was used AS SSD Benchmark 1.9.5986 . According to the specifications intel page sequential write speed dberia be 400mb / s . The bios was set to AHCI mode before installing Windows x64 and intel® Solid State Drive Toolbox according to the firware is updated .
Community Manager
Pipet,
We use IOmeter* to perform the tests in our SSDs, this because we can handle the queue depth on it and provide valid information.
Please find in this http://www.intel.com/content/dam/support/us/en/documents/ssdc/hpssd/ssd-750/sb/intel_ssd_750_series_... link how to configure the program to properly provide scores.
If you need to download IOmeter*, here is the http://www.iometer.org/doc/downloads.html link.
As well, we do know that CystalDiskMark is accurate at providing scores, if you want to try it here is the https://osdn.jp/projects/crystaldiskmark/downloads/65730/CrystalDiskMark5_1_2-en.exe/ link.
Please let us know if you require further assistance.
NC
Community Manager
Pipet,
We are following up this thread and we would like to know if you require further assistance. We will be waiting for your response.
NC
jjuua
Sorry for the delay. Deputy results
Community Manager
Pipet,
Thanks for the reply.
Could you please attach the *.csv file in order to verify the settings?
Also, please let us know if the test was for reading or writing, this because you should run two tests, one for sequential read and the other one for sequential write. Please attach the two files.
If you have questions, please let us know so we can assist you.
NC
Community Manager
Pipet,
We are following up and we would like to know if you can share the files with us or if you need any further assistance.
NC
