Community
cancel
Showing results for
Search instead for
Did you mean:
黎安
ssd 每次关机unsafe shutdown 就会加一,求解?
intel520ssd每次关机unsafe shutdown都会加以,睡眠也会,重启不会,拆掉机械硬盘,换Intel快速存储驱动,关掉w10快速启动都没有效果,求助?
Tags (1)
Community Manager
Hello mailto:2580985067@qq.com 2580985067@qq.com,
As per our translation application, we understand the "Unsafe Shutdown" attribute of your Intel® SSD 520 Series is being increased everytime your computer goes into sleep mode. This does not increase when you restart your system.
Please keep in mind that this is an "event count" attribute. This number increases whenever your drive is powered down without receiving the "STANDBY IMMEDIATE" command first. While this is not ideal and could potentially result in data corruption, it should not affect the overall health of your drive.
In order to better assist you, we would like to have some more information:
1. Is your SSD being used as the boot drive, or a storage unit?
2. Is your SSD connectd directly to your system via SATA, or through a SATA to USB adapter?
3. Is the SATA mode in your BIOS set to IDE, RAID, or AHCI?
4. Using the https://downloadcenter.intel.com/download/26574/Intel-Solid-State-Drive-Toolbox Intel® SSD Toolbox, please select the "export" option and share the resulting log file with us by switching to the "advanced editor" while replying.
We look forward to hearing back from you.
Carlos A.
黎安
1,是作为引导的ssd
2,是直接通过SATA连接
3,BIOS设置为AHCI
'ID' '描述' '原始值' '标准值' '阈值' '操作'5 Re-allocated Sector Count01000 随时可用。9 Power-On Hours Count1013990 随时可用。0C Power Cycle Count3831000 随时可用。AA Available Reserved Space010010 随时可用。AB Program Fail Count0100<span style="color: # 000000; font-...
Community Manager
Thank you for this information.
Please keep in mind that the Unsafe Shutdown Count measures events that happen to your drive, not because of your drive.
In this case our main recommendation will be to make sure that your laptop is using the latest BIOS version available from your computer manufacturer. You can also make sure that your SSD is using the latest firmware version available.
- https://www.asus.com/Commercial-Notebooks/ASUSPRO_ESSENTIAL_P43SJ/HelpDesk_Download/ Downloads for ASUS PRO ESSENTIAL P43SJ*
NOTE: Any links provided for third party tools or sites are offered for your convenience and should not be viewed as an endorsement by Intel® of the content, products, or services offered there. We do not offer support for any third party tool mentioned here.
Aside from this, your SSD looks to be in perfect health.
Carlos A.
IIanM
这你就错怪硬盘了。造成这个问题的直接原因是,主机在给硬盘断电前没有发送standby immediate 。根本问题在于,你的主板BIOS存在bug。这个bug常见于一些预置低转速、会在空闲时自动缩回磁头的机械硬盘的电脑。没办法,OEM厂商给普通消费者开发硬件就是这个态度。
