Community
cancel
Showing results for
Search instead for
Did you mean:
RMerl1
ssd 520 series 180gb warranty to 2017
Well I have a ssd 520 series 180gb and the warranty is untill 2017 so I am wondering where shall I send it because sometimes the ssd workes but simetimes not, I live in Sweden.
I have used it as an master with my hp z820 but there has been issues latly because it would not boot up but yesterday it worked fine ?
So where shall I send it to, thanks (tack) /Robert
Kevin_M_Intel
Hello RFM,
Please make sure the SSD fits correctly on your system. If it does not the SATA connection may be loose and this can be causing the issue your experimenting with the computer.
You can also try the SSD connected externally to another system for testing purposes but if you can contact our phone/email/chat support if a replacement is needed.
Here is our contact information:
http://www.intel.com/p/en_US/support/contactsupport http://www.intel.com/p/en_US/support/contactsupport
Kevin M
