Solid State Drives
Support for Issues Related to Intel® Solid State Drives
Welcome to the Intel Community. If you get an answer you like, please mark it as an Accepted Solution to help others. Thank you!
4365 Discussions
ssd dissapeared from bios
Community Manager
Hi, I have the Asus p7p55d-epro m/b and three hd's in my pc. One SSD intelx25 (SataII) and two WD 1tb (SataIII). For months the system worked properly. (I had updated the firmware of the WD hd's and the bios too ). -I used the settings in the bios Sata as Ide-.
So, yesterday I tried OC from the bios the PC with the autotune-good performance mode and the utility started for about 5 minutes to make the settings for the OC. After that the PC was autotuned but SSD (where the Windows are placed) wasn't recognised at all. I tried to run bios again and LOAD Default settings. The PC started again but this time my RAM frequency appeared as 1067mhz (but it's actually 1333) and the SSD didn't appeared yet. Please help.
Community Manager
If you go into the BIOS and manually force detection, does it work?
Can you test SSD in another system?
Your RAM timings are probably at 1066MHz.. one of the standard timings. You can just change the multiplier after confirming voltage and timings are correct.
Community Manager
No,it doesn't work in another system and neither worked when I tried to force it in my system.Thanks
