Community
cancel
Showing results for
Search instead for
Did you mean:
APrep
ssd e5400s slow write speed?
my seq read speed is above 540mbps all the time but my seq write speed starts at approximately 400mbps and goes down pretty fast, why? i get lik 180-150-200 write speed in benchmarks
APrep
i also have my windows installed in legacy mode, should i change it to UEFI?
Community Manager
Hello dehLord,
Thanks for posting in our communities. We understand that you're experiencing a relatively slow sequential write speed on your Intel® SSD E 5400s Series.
In order to better assist you, please provide us with following information:
- What tool are you using for benchmarks?
- Please download and run the https://downloadcenter.intel.com/download/25293/Intel-System-Support-Utility-for-Windows-?product=91... Intel® System Support Utility and share the resulting report with us. This will provide us with the exact SSD model and your system general specs.
Eugenio F.
APrep
I used AS SSD Benchmark and CrystalDiskMark. I attached the file you requested.
Community Manager
Hello dehLord,
Thanks for your reply.
The https://ark.intel.com/products/94440/Intel-SSD-E-5400s-Series-120GB-2_5in-SATA-6Gbs-16nm-TLC Intel® SSD E 5400s Series (120GB, 2.5in) official benchmark sequential write is up to 400 MB/s. Please note that these results were taken from a fresh OS installation (Windows 7* SP1), with the SSD connected as a secondary unit and no data on it.
From the log provided, we can see the Intel® SSD E 5400s Series is your boot drive. That plus several processes running on the back will affect the results. To obtain benchmark numbers closer to the advertised, we recommend to run a secure erase on the SSD and connect it as a secondary unit if possible.
Let us know if there's anything else we can do for you.
Eugenio F.
APrep
Yes, i have one more question: how do i proceed to reinstall my windows? I just have to do a normal format or i need to use secure erase?
Community Manager
Hello dehLord,
A secure erase is recommended in this case. However, since this is your current boot device, Windows* will not allow you to wipe the SSD.
If you can connect it to a different system or boot from a different drive, you can use Microsoft DiskPart* to secure erase the SSD as shown https://www.intel.com/content/www/us/en/support/articles/000022179/memory-and-storage.html here. If this is not an option, you may proceed with a fresh OS installation.
Please bear in mind that if you're planning to keep using the Intel® SSD E 5400s Series as your boot drive, the results might not vary from the current installation.
Eugenio F.
APrep
I'm aware of that! Thanks a lot for your response!
