Community
cancel
Showing results for
Search instead for
Did you mean:
agodk
ssd write speed problem on intel 6 and 7 series
Jump to solution
hi there;
First of all i am not quite sure if i wrote this threat on right place. so sorry if its wrong.
i have problem with my ssd s in Intel chipsets. Ive 2 diffrent brand ssd s which is supports 500mb/s read and write.
i was tried this thing on my mobo which has z77a chipset with sata3 ports and also my laptop with mobile 6 series which is also have support for sata 3
so long story short with bothbrand ssd and either chipsets i can see 500mb/s read speeds but non of them can see more than 130 mb/s write speed with atto and cdm.
using latest RST and drivers also firmware for ssd s and bioses for mainboards. ah before forget i know its not affect that much but also i was tried with different sata cables.
what do you think about that?
ive really appreciate help
thnx.
regards
AP16
Valued Contributor III
Corsair Force GS series are based on SandForce, so peak speed writes possible only on compressible data, benchmarks usually avoids compression factor in tests.
AP16
agodk
so what about kingston ssdnow300v series?
agodk
Thnx for answer JFF. after your reply i was tried with Sandisk so eveythings fine i was able to see 300mb/s
so i was choose wrong brand at first place.
Thnx and regards
